CL-Class (W215) 2000-2006: CL 500, CL 600
Cooling fan problem
Old Feb 25, 2016 | 10:40 AM
detroit442's Avatar
CL500, E430
Cooling fan problem
Do any of the S.A.M.s control the radiator fan? My indy shop said that the fan can be turned on by computer and operates at all speeds. There is no faults with the sensors or relays. I do have a malfunctioning S.A.M., could that be the problem?
Old Feb 26, 2016 | 06:06 PM
tusabes's Avatar
Mercedes
If the fan is on high all the time it usually means the ecu is water damaged
If you have a bad SAM I assume that too is water damaged
You'll probably need both a new ecu and SAM
Old Feb 26, 2016 | 06:11 PM
detroit442's Avatar
CL500, E430
Thanks for the reply. The fan doesn't come on at all under its own, but can be triggered with diagnostics. Do you happen to know which SAM controls the fan?
Thanks,
Old Feb 27, 2016 | 09:17 PM
ItalianJoe1's Avatar
2003 CL 600
If the ECU isn't commanding the fan, you need to look at why. Is there a faulty engine temp sensor and it thinks it doesn't need the fan? Also, there should be a fan request PID in the data, see if the ECU is asking for the fan and not getting it, it should always go on when the a/c is active so it's simple to test. That should give you an idea of where in the chain the breakdown is.
Old Feb 28, 2016 | 06:20 PM
detroit442's Avatar
CL500, E430
I just did the test. I started the engine and let it warm up a little. I engaged the A/C and the fan did not start. I spun the blades with my hand and it started. My guess is a bad electric motor.
Old Feb 28, 2016 | 07:27 PM
2003 CL 600
There ya go. Replace the fan, not too bad of a job on this car.
Old Mar 9, 2016 | 03:38 PM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
They are expensice though... There was a guy here who just replaced the Motor and it was rather "cheap" compared to a all new fan assembly.
Old Mar 9, 2016 | 05:02 PM
LynnBilodeau's Avatar
SL55, Opel GT, 70 LT-1, BMW 745 turbo, MRoadster, 49 Stude truck, 69 Z/28, Ferrari project
Without the A/C on, at what temp should the fan engage (factory settings)?
Just curious.
Old Mar 11, 2016 | 11:20 AM
2003 CL 600
I spent about $290 on a complete fan with controller, I don't know if i'd risk it to just change the motor but it's up to you.
Just curious.
My car heats up to 95C on the gauge before the fan kicks on if I don't have the a/c running.
