Starting issue
I ran into a situation today that's new to me. The engine turned normally when trying to start but didn't turn over. I tried several times after turning everything off. I waited , while calling a tow truck, then tried it again and it started. Is this a prelude to something major?
Was the car warm (recently driven) when it refused to start ? A car that will not start when warm but will start once it cools off has a bad cps , very common problem and very easy fix
Here's a video
Originally Posted by tusabes
(Post 6640908)
How to change crank position sensor (symptom: car will not restart when warm , but will start once it cools off )
2000 - 2006 Mercedes Benz S500 - Crankshaft Position Sensor - Engine Stops - Engine Won't Start - YouTube |
i had a similar problem and it turned out to be the ignition regulator, but that's expensive. i'd pursue the cps first.
Thanks! I'm going to check out the cps first. Is there a diagnostic that can be run to determine the cps vs the ignition regulator?
You didn't say whether the car was warm when it didn't start
That's the symptom for a bad cps - no start when the car was warm |
Yes, the car was warm. My check coolant light had just come on.
