Shifter linkage retaining clip
Hey to all,
I am looking for the retaining clip that goes on after the shifter linkage and transmission linkage is connected. I put the shifters linkage back on to the transmission linkage and put the retaining clip back on but I must of put it on wrong or did not seat it correctly, so it come off and I am stuck in reverse. I did the shifter repair with the aluminum piece, all was good with the test drive all gears no issues until I get home and backing into my driveway and when I tried to go to park it was not changing it was in reverse and the shifter was moving to easy, got under car and the transmission linkage had come off the shifter linkage because of the clip. Need a clip, please help. Thanks. |
From direct experience, its not really safe to re-use those clips. I got mine from the dealer.
Nick |
Retaining clip
Did they have it on hand in stock or have to order it, if so how long did it take to get it?
Its a cheap little thing and it was in stock.
Nick |
Thanks Welwynnick for your reply, I was able to get the clip at my local dealership now I have that clip and on THE CORRECT way and my shifter working just fine.
I appreciate your help.. |
do you have the part # and price?
thanks |
I am pretty sure this is the part number: 000-994-43-60.
They had given me the wrong clip at first which I had them correct, but I have both invoices and I am fairly confident this is the one with the correct part number. The bushing part # 202-992-00-10. Lock clip was:$1.40. Bushing was: $2.40. |
thank you. can't believe it was so cheap.:)
