00 CL500 Changed battery vehicle won't turnover when I turn the key.
Took vehicle to get detailed, they left doors open overnite to dry carpet. Ignitiion will not turnover engine.
Pulled battery to recharge it, fully charged 850 cranking amps but still will not turnover.? Also No brake lights now? No clock display on dash? Sunroof not working? Rear windows not working? Is there a process I have to do after installing a battery? |
Still does not turn over.
Checked fuse and found a 5 amp under pass rear seat blown.
Replaced it and still does not turn over. All was fine till it went into detail. Now will not turn over. Can anyone help? Suggestions please. |
I am having the same problem . there were no replies to your post . Sad... Sense your problem was in Jan. I hope your problem has bee resolved and you will share .
Thanks, CL500 fix |
See reply
Originally Posted by tusabes
(Post 7103174)
first check the main fuse under the passenger floor
https://i171.photobucket.com/albums/...A2597E26CF.jpg this video shows how to get to it https://youtu.be/Jb_7E-Z5D7g if it's not the main fuse , then it's time to buy a new battery |
try disconnect the battery again for 1 hour
reconnect after that, once you key turns: http://www.benzworld.org/forums/c208...procedure.html |
