CL600 lower coolant hose replace
03 CL600
Anyone have tips or tricks on changing out the lower coolant hose?
One end appears next to impossible to remove. I'm inclined to think the radiator has to be removed.
Also,, anyone have a handy diagram of the aux cooler mounting and hose routine? My Aux cooler is gone, bypassed by using earlier non aux cooler parts. I've acquired a what I think is a complete Aux radiator set up.
I've put a few miles on it, and now the gremlins are out in full strength. Big oil leak from the front, above the lower pan. Probably the dreaded oil cooler -- pull the intake and heads to fix most likely.
03 CL600
03 CL600
Much thanks. Yes, the leak appears to be the pump. Just ordered one. Do you have any similar diagrams of the aux radiator and how it installs? I have only an aux cooler. No hardware. I might be missing some brackets. Not sure yet.
