Airmatic to Air suspension conversion?
Hey,
Did anyone ever thought about making airmatic to bags? Example. accuair?
I am looking for plug and play kit but having troubles to success.
I knowtheres a CL 55 in this forum that was done like this.
A cl does not have airmatic .
They all have abc which is a hydraulic suspension , not an air suspension . Only the sedan had airmatic or abc depending on model
you've seen the one cl converted from hydraulic to custom bagged suspension . That's the only one that's ever been done as it required custom fabricated suspension. There is NO plug and play conversion for a CL
if you had a sedan
there have been some s classes converted to a custom bagged setup . You can also get a kangAIRoo controller which turns the factory s class airmatic into manually adjustable air suspension.
if you had a sedan
