CL-Class (W215) 2000-2006: CL 500, CL 600
2003 CL600 SRS Warning on Dash came back after repair
Old 05-26-2017, 01:04 PM
sker66's Avatar
2003 CL600 RentechCL65mod, E55 (sold), E63
2003 CL600 SRS Warning on Dash came back after repair after spending $800 to replace the control unit. This happened about 3 months after the repair and the Mercedes mechanic I used will not stand by it after that long. He states he can replace again but that makes no sense to me. Is there a way to stop the SRS warning indicator to stop comeing up on the dash every time I start the car?
Old 05-26-2017, 03:43 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Nope, what you needed months ago was a mechanic with DAS Xentry who would have found the issue in minutes and corrected---now you need the same guy and more money or sell the car to some sap who doesn't know what SRS means.
Old 05-26-2017, 03:48 PM
tusabes's Avatar
Mercedes
Lots of things can trigger the srs light
Most often it is the passebger side seat sensor
Old 05-26-2017, 06:53 PM
member
pmercury's Avatar
CL
lots of things like wrong variant coding and wrong coding parameters
you need someone with DAS at least and if possible developer mode
sometimes a stupid-*** programs a new module without resetting some concerned connected modules
so everything works until the system resets by itself, and the error appears
don't stress too much, as Plutoe said, you should have done that in the first place
just hook up Xentry
75¨% of MB dealers are rip-offs and/or ignorant
Old 05-27-2017, 12:52 AM
graytalon2000's Avatar
05 CL600
Tusabes is right about the passenger seat bottom sensor. I have trouble with mine occasionally. Another option for you is to get a scanner that reads Euro car codes. I use a Carsoft scanner and it will read every system on my car and will clear any codes. You could pull up any SRS codes and go from there. Sometimes, just clearing the code will "fix" the problem but most likely any code found will point you to the problem.
Quick Reply: 2003 CL600 SRS Warning on Dash came back after repair
