How To connect your aftermarket stereo
Let's make it quick
The alixpress sellers lie to you and tell you that you need a fiberoptic decoder to keep your fiberoptic amp connection
yes, you would, but as it is a D2B and not MOST protocol you can't decode that, their 99$ box won't work
what I did is I bought a 2017 5 channel amp 4 x mono + automatic woofer output
I did not want any of their crappy antennas so I connected everything to stock
TV
GPS
and radio
Radio is to connect in the front with a adapter they give you with the radio
GPS is also in the front
just cut the stock plug and solder the radio gps antenna plug
HD terrestrial tv box has two antennas
cut the wires (they are long and do the job to the front ) of the two antennas and connect them to the trunk antennas ( car has 4 )
so black and red to one cable
yellow and blue to the other cable
after tests that works the best when you drive and move
now for the amp it's very standard
just RCA 2 x stereo from the front to the trunk new amp
then cut the following wires as they go to the speakers
On the big plug, cut of these
front left = green /green brown second = always - Negativ
rear left = pink / pink brown
front right = black / black brown
rear right = white / brown
Subwoofer = Blue / blue brown
gray white / green white is a extra mono speaker 'not to use in this config)
all the other wires are useless
you have to use a amp with crossover filtering like mine
mine is FOCAL FPX 5.1200
this because the front speakers can't take all bass frequencies
have fun !
TV
GPS
and radio
have fun !
biker349 (04-24-2021)
I now replaced the subwoofer with a Morel UW 1058
this woofer
this woofer
Great info! Does each quadrant include the multiset speakers?
in my SL I have a center channel, a sub, 2 speakers in each door and two little tweeters in each seatbelt... I suspect the doors are one channel each seatbelt tweeter are a channel, the center channel is 1 and the sub is also 1
Thoughts? Also do you happen to remember what the impedance of your speakers were?
you just hook the whole stuff up from the original amp location as I did
make sure you use the crossover filter settings on the amp, to cut off bass on those front speakers
this amp has some power so be careful to not blow the front. there is also a little total power preset device
best is to set max limit
that way you won't have a retard turning the volume full up and blow your speakers
don't worry about the ohms, the amp takes both
this amp is the top of the top
I prolly wont buy a Focal amp for this but thinking one of the Digital Alpine amps because of their size.
SPONSOR
WWW.BENZNINJA.COM
first had tv box and more hooked up but after mounting my whater/meth kit I didn't even put that stuff back as my car sound is so sick that I never ever listen to music anymore
engine is much better
but just tell me what you didn't understand or what you need to know
I'll be glad to help you
I wanted to install one of those android radios. But don’t want change the upper button control panel. . So going to use the excisisting face plate . With one of those 10.5 inch displays and also my Bose amp burnt out. So gonna change the amp. And was trying to better understand using the gps antennas that are in the trunk . And want to be able to watch tv. In the USa
SPONSOR
WWW.BENZNINJA.COM
I found some 11" ultra wide while ago. wide instead of high
can't find any now but search
then
don't forget that the connection on this one below and all others is just a plate mount with a hole, letting a wire pass with a plug
so my Idea was, first try the radio upside down , middle attachment point seems not to be centered.
then, other possibility would be to adapt a little plate
example radios I target are here:
https://www.aliexpress.com/item/4001223737884.html
even on this system you could make a adapter plate as it always is one wire bundle running
you mean like just to install it vertically instead of horizontal.. yeah i like the concept of these radios as the face swivels-11 inch wide should be enough to cover the hole .. i got a trim from an s500 i was going to start working with .so i can cut it up and see what it looks like after the the 3 holes have been cut out to make the 2 din hole
SPONSOR
WWW.BENZNINJA.COM
no I mean upside down if the center socket is not centered
Let's make it quick
TV
GPS
and radio
have fun !
TV
GPS
and radio
have fun !
what about this one ?
Getting ready to do this
What's up went with the Joying 11.5 inch display with a Ds 18 amp here is some pictures before I start the project
I have a bezel from w220 as template . 2 Din radio
DS18 Amp class D 5 channel 2000 watt
Perfect size 2 ohm amp
What's up y'all. So ran in to a problem . Accidentally shorted the cigarette lighter . trying to get .accessory power. Then lost 12 volt power to the command . And lost communication with TCM ..wtf ...any help please . Thanks in advance.also climate co trol Lost power when I accidentally places center close on top of the shifter when I was placeing radio and console back in position ..
SPONSOR
WWW.BENZNINJA.COM
JRAZ305 (05-21-2021)
