The dreaded “non-serviceable” m113 intake manifold re-seal DIY
Intro/theory-
If you’ve seen my other thread lately, you’ll know I have taken the top off my intake manifold to vacuum some debris out of my cylinder heads
this is a huge no-no according to mercedes. Apparently the entire intake manifold is supposed to be removed instead and the manifold should never be opened. Whoops too late! I’ve read this is because the manifold is tricky to seal, so I wanted to start this thread to document my process with pictures and explanations of results
I’m kinda glad I split the manifold because this thing was absolutely filthy inside. And if you’re into the performance world you’ll know this robs your engine of power
there isn’t a lot of info online about working on these manifolds, and most of whats online has old photobucket photos which are no longer available, making the threads and info halfway useless
on the subject of this part being “non serviceable” I personally think that is a joke. It’s good in theory, it prevents a lot of people from doing a half assed job on sealing their manifold and ruining their cars performance with vacuum leaks. If you remember right our transmissions were “non serviceable” and “sealed for life”, what a joke. It’s this same “non serviceable” attitude that I believe ruined the reputation of the Abc system, because if mercedes developed and shared a PROPER maintenance schedule for Abc, we would have seen exponentially fewer abc failures in my opinion, but I digress
like I mentioned, this part has been serviced before with success. In fact in the 2000’s there were multiple people opening these manifolds to port and polish them, one user claimed an Hp gain of 20. I wish I had more time to devote to porting and polishing my intake, but unfortunately I have just bought a house and this intake repair job couldn’t have come at a worse time. Apparently it takes upwards of 80 manhours to properly port and polish these manifolds, yikes . But a 20 horsepower gain for $0 is right up my alley haha
heres some pics of my manifold top piece after being painted with DupliColor engine enamel, color Aluminum. No other color looks right in my opinion. And remember you want very very thin layers of paint because unfortunately painting these pieces will make it retain heat and possibly lose some power. I however am looking to ultimately restore my mercedes to a really stellar condition all around
Prep/application of sealant
To clean and prep these pieces I started spraying with brake cleaner, it was clear a brake cleaner bath would not get these pieces clean
cleanliness is absolutely crucial to applying sealant to metals
so what I did is I soaked the pieces overnight in some gasoline. Make sure to keep the plastic brake vacuum barb OUT of your gas/brake cleaner bath. I believe fuel and brake cleaner will eat away the plastic
after soaking overnight, I scrubbed all the pieces until they were visually clean. This fuel bath helps a lot to loosen all the old sealant and old glue. After a fuel bath the pieces will be coated in a thin oily film. Now here’s where you spray them down with brake cleaner again
removing all of the old sealant is also absolutely crucial to adding new sealant
so here’s a photo, maybe the only one on the internet, that shows the sealant pattern for the inside of the upper manifold. Keep in mind this is a very hasty application of high temp RTV and I ended up removing and re-doing the sealant. Main issue with this sealant application job was using too much sealant. Not only is this going to have too much push-out , but this will also inhibit air flow through the manifold with how much extra sealant would be squeezed out. It could even possibly break off in pieces and get sucked into the cylinder head. Not good
be prepared to do the same if you want proper results
Please note- the very top and bottom line of sealant, I did not find these lines of sealant when dismantling it. I’m not sure if those parts had sealant originally but I don’t see what it would hurt
To start I took apart the pieces and studied the patterns of sealant and glue meticulously. This is very important for getting the right patterns. You’ll see where the old sealant goes after stripping and cleaning the pieces. It’s pretty clear where the Sealant goes because it will be the only strips on the manifold that isn’t discolored with oil film
biker349 (03-18-2019)
I have finished this job, glad to clean my intake manifold and vacuum out the debris i dropped into my cylinder heads/cylinders. I'm still getting those same pesky p0131 p0151 codes after doing tons of maintenance like MAF, de-cat, etc etc. perhaps it's just failing primary o2 sensors as they are about 17 years old with over 100k miles. from what i've read they usually last about 80k miles.
another possibility is always i have a leak in my upper intake manifold re-seal. should be fairly easy to check with some butane gas i assume?
Forgot to update this thread
a friend bought a smoke testing machine, we tested my intake and sure enough no visible leaks!
finishing up a forced induction project now so we will see how this re-sealing job really pans out
after some time has passed, I would say this job is able to be conquered successfully despite Mercedes Benz recommendations against it, however to do this job correctly you should expect to spend a lot of time on it
ChrisVannoy (11-04-2020)
