CL-Class (W215) 2000-2006: CL 500, CL 600
CL600W215Biturbo
Old May 11, 2020 | 05:25 AM
Australia's Avatar
Mercedes CL600 2003
CL600W215Biturbo
Does anybody have these problems and solutions and why they occur so young in a car like mine (110k)
Shock absorbers top mounts
Brake hoses cracked (fore)
Gearbox rubber mount sags
caster arm bushes
Control arm arm ball joints
o/SF inner track rod
water pump leaking
The biggest issue is the front shock top mounts which have c20 mm of play (up and down). . I don't want to replace the whole unit as I have replaced the oil annually to keep in top condition
Why does all this happen so easily on this car and where do I get parts ?
Old May 11, 2020 | 09:55 AM
pmercury's Avatar
member
CL
probably your extreme heat and dry air downunder
https://mbworld.org/forums/cl-class-...op-mounts.html
and this
post 15
https://mbworld.org/forums/cl-class-...n-bars-dy.html
if you need all the part numbers for oem, or in europe there are many aftermarket replacement if you want a great price
post your vin
cheers
