CL-Class (W215) 2000-2006: CL 500, CL 600
2004 cl500
Old Apr 14, 2021 | 11:26 AM
Jtgmercedesguy's Avatar
2004 Mercedes cl500
2004 cl500
Hi I’m looking at purchasing a 2004 cl500 . Has the abc suspension, the owner told me when it sits maybe a few hours or def overnight the rear lowers itself not the front . When he starts the car it levels itself back and no problems after that and when driving . He said the power steering pump was changed oil changed and the front 2 actuators were changed but not the rear. What do tou think the problem is and what poss it might cost ? Thank you
Old Apr 14, 2021 | 02:25 PM
Iworshiplemons's Avatar
2002 SL600 V12
You're leaking fluid somewhere. Either some valves are stuck, or it's blown a line or a seal somewhere.
Do yourself a favor, and unless you're just in love with the ABC system, delete it all with a Ceika kit (or strutmasters, I guess..) and call it a day.
If you are in love with the ABC, ask yourself if it's worth thousands of dollars worth of maintenance. If it is, then get after it. And buy a STAR.
Old Apr 20, 2021 | 07:47 AM
renault12ts's Avatar
W215 CL500 2005
Valve block at the rear is leaking. Not a difficult fix nowadays, they can be rebuilt with new o seals. It is something that will need done...but not immediately. Use it as a bargaining point.
Old Apr 21, 2021 | 10:16 AM
RScott's Avatar
S55, SL500, 500SL
You can get a kit to reseal a valve block for not much money from ebay. The book time to remove a valve block is about 1-1/2 hours, and the time to replace the seals is perhaps 15 minutes. I've never done this job, but a friend of mine has done it twice and states that it really isn't difficult at all.
Also, you needn't do anything at all. I have an S55 that drops an inch or two overnight, and it really doesn't bother me that much. I've already got a seal kit on hand for a rebuild in case the dropping issue gets considerably worse.
