CL-Class (W216) 2007-Present: CL 500, CL 600
Sunroof Crank Tool
Old Jul 6, 2017 | 06:38 AM
Rick Cell's Avatar
S65 Coupe SL63 ML63
Sunroof Crank Tool
For the 2008 model year did Mercedes provide with the car when new a sunroof tool to manually close the sunroof?
Old Jul 6, 2017 | 03:52 PM
steveb9771's Avatar
2007 CL550
No tool supplied for 2008 and there might be no place to use it if you had one. The 2007 owner's manual shows the tool and provides instructions on how to use it. There is no mention of the tool in the 2008 owner's manual.
from 2007 owner's manual page 268:
Controls in detail
Power tilt/sliding sunroof
Synchronizing
The tilt/sliding sunroof must be synchronized
  • after the tilt/sliding sunroof has been
    closed manually (page 638)
  • if the tilt/sliding sunroof can only be
    opened with a jerking motiom
  • after a malfunction
following from 2008 owner's manual page 508:
Synchronizing
    opened with a jerking motion
Note no mention of manual closing for 2008
Old Jul 6, 2017 | 09:34 PM
Rick Cell's Avatar
S65 Coupe SL63 ML63
Steve thank you for your response. There is a plug above the drivers side sun visor that you can remove so I put a generic allen key in the hardware and it fit but I did not try to turn it and see if the sunroof moved.
