CL-Class (W216) 2007-Present: CL 500, CL 600
Bulb list
Old Oct 25, 2018 | 08:48 AM
Tommy jenko's Avatar
CL500 w216
Bulb list
Hi does anybody have the full interior and exterior bulb list for the 216 cl as I want to upgrade the old halogens to led
Old Oct 25, 2018 | 09:43 AM
AZN Optics's Avatar
SPONSOR/MBworld Guru
Year?
Old Oct 25, 2018 | 12:54 PM
CL500 w216
Originally Posted by AZN Optics
Year?
pre facelift 08
Old Oct 25, 2018 | 01:19 PM
AZN Optics's Avatar
Low Beams: D2S
High Beams: H7
Fogs: Either H7 or H11 depending on package (check your owner's manual)
Front signals: 5200
Front Parking/City lights: 194 wedge
Front sidemarkers: 194 wedge
Rear Plates: 194 wedge
Interior dome: 41mm festoon
Interior map lights: 41mm festoon
Trunk/Cargo lights: 41mm festoon
Let us know if we can help you out with any replacements. We specialize in canbus enabled upgrades so error free.
Old Oct 25, 2018 | 10:24 PM
steveb9771's Avatar
2007 CL550
Low Beams: D2S
High Beams: H7
Front signals: 5200
The above list is INCORRECT. All US pre-facelift W21 vehicles used bi-xenon headlights and did not have separate low and high beam bulbs. Given this error, all of the other bulbs are suspect.
Old Oct 25, 2018 | 11:43 PM
AZN Optics's Avatar
um... Ok...
http://www.autooutletnj.com/detail-2008-mercedes~benz-cl~class-cl550_2dr_coupe_5_5l_v8-used-16939016.html
https://youtu.be/wKVhB9BiDDg
sure does look like split bulbs to me. Yes, bixenon D2S, but separate additional high beam...
And just to further prove...
https://www.sylvania-automotive.com/apps/vlrg-us/Vlrg/?y=2008&make=mercedes-benz&model=cl550&pos=forward-headlightbulblowbeam
Old Oct 26, 2018 | 04:40 AM
steveb9771's Avatar
2007 CL550
The inner bulbs are NOT traditional headlights. For vehicles with night vision, they are IR emitters which produce IR light which is not visible to the eye. For vehicles without night vision, I believe they are dummys.
Old Oct 27, 2018 | 02:01 AM
AZN Optics's Avatar
Yes behind the halogen projectors, IR emitters are there, but so are the high bulb. Easy way to confirm... Turn on your high beams when low beams are off to not engage the shutter. Or open the hood and remove the dust cover behind the inner housing to see the bulb there. Or check page 689 of your owners manual which specifically says High Beam Flasher Lamp H7 and those with emitters, H11 bulbs. MB doesn't just throw in costly projectors for no reason.
Old Oct 27, 2018 | 02:04 AM
AZN Optics's Avatar
And if you don't have your owners manual handy...
https://www.mbusa.com/mercedes/servi...class=CL-Class
Old Oct 28, 2018 | 07:46 PM
lkchris's Avatar
'10 CL550, '12 GL550
While there is a motor system to create a long beam via the HID bulb, there is also a separate Halogen H7 operating as a high beam as well. This is because hid bulbs are unsuitable as flashers due to their slow warmup time. When you flash your flashers,nothing happens with respect to the hids.
Old Oct 28, 2018 | 08:16 PM
AZN Optics's Avatar
Yup. What ☝️ said
