W216 AM Antenna Location
Can anyone advise where the AM Antenna is located on a 2007 CL600. I think I have a loose connection as the AM radio cuts out momentarily and causes static when I hit a bump. It seems to work fine when the car is stationary. FM works fine and so does the CD player. Only happens on AM.
What is AM? Do you mean, in the morning?
AM radio is 535 KHZ to 1.7 MHZ Amplitude Modulation
FM radio is 88MHZ to 108MHZ Frequency Modulation |
Probably in rear window glass
