CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Pedals
Old 06-09-2006, 11:40 PM
raycanales's Avatar
2017 E400 CAB 2007 BMW 650i CONV
Pics
rather easy .. from 1-10 like a 2
Old 06-12-2006, 02:20 AM
phat-ho's Avatar
2003 CL500
ha ha YES! looking s-h-a-r-p ! ! !
Old 06-12-2006, 05:03 PM
red00lght's Avatar
2006 ML500
Is it just a simple bolt on? I'd like to get these for my CL600....
Old 06-12-2006, 05:17 PM
raycanales's Avatar
yes simple is the correct answer the hardest part was keeping my scotch from spilling on the carpet ....
next are the wheels for me .... still debating
Renntech Monolites or HRE 547R
Old 06-18-2006, 08:44 AM
V12toHybrid's Avatar
Kia Sedona
i can't find the parts at mercedesshop (or any online parts place) with the part number posted here. where have you guys been getting them from? what year slk?
Old 06-18-2006, 11:29 AM
shanta's Avatar
call or email Phil @ Mercedesshop, or call Rusty @ buymbparts...not all parts can be ordered online
Old 06-18-2006, 05:10 PM
  #32
jsloan01's Avatar
Metro Card : (
looks good man. those were identical to what came stock in my C 230!!!
Old 06-30-2006, 11:57 AM
  #33
03CL55AMG's Avatar
2003 CL55 AMG
Pedals look great. I bought a set from my local MB dealer. Having a hard time installing the brake pedal. I get three corners of the replacement pad around the bare metal pedal and cannot seat the pad down on the fourth corner. Extremely tight...do I need any special tool? I also looked at the stock accelerator pedal and how do I remove that plastic pin? Looks as though it has some type of metal fastener clamped on right side. Thanks for your help on this!
Old 08-28-2006, 06:22 PM
  #34
phat-ho's Avatar
2003 CL500
ok, i finally had the time and motivation to install them and i
thought i crapped myself trying to get the brake pedal on. i couldn't get the gas pedal on. need help. my pin won't come out and at the same time i don't want to break it. even after i do remove it, how do i slip the new one on? the opening at the rubber base is not wide enough to slide past the 'wedge' with the pin hole
Old 08-28-2006, 10:54 PM
  #35
shanta's Avatar
it is really not that hard...
either pull the pin or push it out for the other end
the new pedal will fit just fine, the rubber base stretches enough to get it past the pin hole...
Old 08-29-2006, 09:23 AM
  #36
phat-ho's Avatar
2003 CL500
thank u, i'll suck it up and try it?
Old 08-29-2006, 09:38 AM
  #37
Kia Sedona
hey phat-ho,
i'm ordering right now from mercedesshop. does it mean that the entire cl population in atl have slk paddles now
Old 08-29-2006, 10:38 AM
  #38
shanta's Avatar
lol...really it is not as bad as you think...
Old 09-02-2006, 12:25 PM
  #39
Kia Sedona
just installed it this am after i leatheriqued the whole interior (used almost 16oz of rejuvenator oil). the process took about 10mins. the small parking break is definitely the hardest one to do. the regular break is easiest. used small flat screwdriver to "round out" the rubber around the metal part. the small pin that holds the gas padle is the self retaining type. used a small plier to pinch the other end and push it in alittle and then you can easily pull it out. then pry open the small round cover on the bottom and un-bolt the nut and pick up the washer with a magnet or small plier. the whole gas padal assembly can then be pulled out. flip it and you will notice a small black rectangle plastic with two prongs that is holding the old gas padal in. remove it by pulling it straight out and replace the the old one with your new metal one and put them all back. it sounds more difficult than it actually is. phat-ho, if you are having trouble, pm me and i can install it for you.
Old 09-03-2006, 01:37 AM
  #40
phat-ho's Avatar
2003 CL500
man, i have not had any time these few days..i have been driving around the regular rubber gas pedal while the other two look great. also, i didn't know mercedesshop was right off of peachtree industrial.
Old 09-03-2006, 08:48 AM
  #41
Kia Sedona
are you sure mercedesshop is off peachtree ind? i know benzmac used to have a repair shop there but it closed down 2yrs ago. i didn't know the parts store is here as well. they got my parts pretty quick though.
Old 09-03-2006, 01:21 PM
  #42
sprins's Avatar
CLK63BS, SL55, G55, C43
Nice. And you vacuumed too!
Say, will these pedals also fit the S55? My guess is yes since the S and CL pedals must match, but can anyone confirm or deny?
Old 09-08-2006, 04:53 PM
  #43
phat-ho's Avatar
2003 CL500
the person i spoke with says they're in atlanta so i got really happy and wanted to pick them up on my way home from work. from what he was telling me it is next to enterprise (literally right down the street from where i work). but they just shipped the package before i could call and ask where my pedals were. maybe i'll stop by someday.
Old 09-08-2006, 10:15 PM
  #44
Kia Sedona
that's great to know. they have great prices and now i can just pick them up. how is the installation coming? it's such a cheap and nice mod. i just installed sprint booster for the cl. the throttle response for low speed is much better now. you should check it out.
Quick Reply: Pedals
