CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Help with trunk
Old Dec 22, 2008 | 10:35 PM
jkirk's Avatar
08 CL-63 AMG
Help with trunk
My trunk opens and stops about two feet short. Is there a way I can fix without taking it in??
Thanks in advance.
jk
Old Dec 23, 2008 | 12:28 PM
mclarenm8d's Avatar
2003 CL55 Kompressor Horizon Blue Metallic
Thanks in advance.
jk
Is it the older style spring loaded, or newer hydraulic? There was a switch over about our model year. The spring loaded have multiple attachment points with the springs to adjust opening force. However, I prefer the lighter setup because on the higher settings there isn't anything to keep the trunk from opening too high, getting caught in the wind, and buckling over. I see more older S/CL with trunk problems than without trunk problems, probably the reason for the design change in the later years.
You can jam a bunch of quarters/washers in the springs to get their compression length to be bigger or get a spring puller so that you can change them to the other attachment locations. Disclaimer, be sure to protect your paint with this operation.
Old Dec 30, 2008 | 12:34 PM
jkirk's Avatar
08 CL-63 AMG
Thanks for the note. I think they are the hydro type. Is that something the dealer has to fix, or can I reset it myself?
Thanks in advance.
jk
