CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Newbie with some performance ?s
Old Dec 12, 2009 | 09:22 AM
6th gear's Avatar
CLS550
Hey guys.So i didnt do my homework and bought a 07 CLS550.I LOVE the car,but i want more HP.Im already bored with its 400 stock hp and iv only owned it for a week.LOL.I know i shouldve bought a AMG and im regreting it now.But as i understand the 55 AMG is the same motor 5.5L V8 just with a blower(kommpresor)??I would really like to beef this thing up.Is there anything i can do?Thanks everyone
Old Dec 12, 2009 | 12:23 PM
mk4mike's Avatar
Sold - CLK500
try and sell it quick and get yourself a cls63! or a 55!
why throw 10k into supercharging it when u can have a complete car without the headache! and under full warranty
Old Dec 12, 2009 | 12:36 PM
CL55_Serge's Avatar
CL65 AMG , white S550 Sport w/ white Giovanna 22s, wild custom chopper
I would not recommend the aftermarket supercharger route. Lots of guys with the last gen M113 215 CLs ran into major motor failures after adding the superchargers. The suggestion of switching out the car for a CL63 actually makes sense to me too. If you read the Mercedes-AMG main website, you will see that AMG moved away from superchargers completely to naturally 6.208 liter aspirated motors M156 in the CL63.
You can do a few things first though, to see if you an quench your thirst for power:
1. ECU programming - not much horsepower, but the car will have nicer pickup in the midrange, more responsiveness and the gas pedal will feel more jerky :-)
2. Better air filters - K&N, stock air box is pretty nice enough already
3. Lighter main pulley
4. Switch out the exhaust manifolds to headers and upgrade the mufflers to get an overall more free flowing exhaust system.
This should bump you up from 382hp stock (somehow you've convinced yourself you have 400) to maybe in the 410-420ish range, but more importantly/noticeably - the car won't be sluggish and will react to throttle immediately.
Old Dec 12, 2009 | 09:33 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Yes, you have a 5.5 but litre size is about the only thing you share in common with a 5.5 AMG Kompressor motor.. For a Naturally aspirated motor,, headers, cams, tuning are your largest gains.. Your compression is pretty high to be able to add much boost from a turbo or S/C..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
