CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Turn the wheel then BOOM. ABC fluid flushed out... HELP! PICS
Old Jan 7, 2010 | 09:43 PM
benz_addict's Avatar
V12TT
Exclamation Turn the wheel then BOOM. ABC fluid flushed out... HELP! PICS
This morning the power steering was making moaning noises so I checked the fluid level it was bone dry. I topped it up this and went to work. On my way home it started making the same noise. Checked the level, dry again. Topped it up and started it in my garage, turned the wheel then BOOM. I started hearing liquid hit the ground really fast like if someone flushed a toilet. I shut off the car immediately, jack it up and see a pool of pentosin oil underneath.
I checked the pump it looks fine. ABC fluid fine, car still rises up etc. Power steering is gone. I can't see any leaks in any lines from underneath or under the hood.
What could it be? Where is it leaking from?
Attached Thumbnails Turn the wheel then BOOM. ABC fluid flushed out... HELP! PICS-dscf0001.jpg   Turn the wheel then BOOM. ABC fluid flushed out... HELP! PICS-dscf0004.jpg   Turn the wheel then BOOM. ABC fluid flushed out... HELP! PICS-dscf0008.jpg   Turn the wheel then BOOM. ABC fluid flushed out... HELP! PICS-dscf0005.jpg   Turn the wheel then BOOM. ABC fluid flushed out... HELP! PICS-dscf0003.jpg
Old Jan 8, 2010 | 01:37 AM
Kar don's Avatar
Mercedes-Benz
how are you assuming it is ABC fluid. This is clearly power steering issue. Could be leaking anywhere, from the rack? lots of places man. Sounds like because you let it go you will need a new power steering pump at the minimum and maybe a new rack... looking at maybe $2000 in parts. Hopefully just the pump...
Old Jan 8, 2010 | 07:47 AM
SLCL's Avatar
CL55, SL500, E350
ABC and Power Steering use the same type of fluid.
ABC and Power Steering use the same pump.
Old Jan 8, 2010 | 07:52 AM
SLCL's Avatar
CL55, SL500, E350
Sounds strange, it looks like one of your PS hoses blew. You might need a lift to check. What was the year and mileage if you don't mind sharing? Thanks.
Old Jan 8, 2010 | 05:50 PM
V12TT
The CL is at 112k miles.
Yeah I think a hose blew that connects to the rack. When ever I turn the car on it starts spitting out the fluid underneath and when I turn it off it stops. It's at the dealership now I will hear back from them on Monday. I just hope I don't need a new pump that would be $$$
Old Jan 8, 2010 | 09:54 PM
SLCL's Avatar
CL55, SL500, E350
You probably had a split on the hose. When you turn the wheel, the pressure increased causing the split to blow, I am guessing.
It's sad to say this but you were "lucky" that it lasted 112K miles before it blew. Anyway, good luck with the outcome.
If you could follow up with the result, I am sure it would benefit some of us. TIA.
Old Jan 9, 2010 | 04:26 PM
V12TT
I'll keep you posted for sure thnx for the help!
Old Jan 9, 2010 | 09:44 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Do not drive without fluid in the reservoir or with the line damaged. If you make the power steering pump fail, you also wipe out the ABC pump since they are one pump. Have the car towed or fix the line that broke before you start or drive the car. The pump is hella expensive to replace!
Old Jan 11, 2010 | 08:13 PM
V12TT
Steering rack is gone. ABC pump ran dry and is gone too. Both front struts are leaking and need to be replaced. Needs ABC fill+rodeo+flush+fill. Dealer is asking total of $11,000+ taxes (CAD). lol.
To those looking to buy a CL55 without warranty, think twice.
Old Jan 11, 2010 | 08:19 PM
SLCL's Avatar
CL55, SL500, E350
oh dear!
Old Jan 11, 2010 | 08:54 PM
V12TT
Originally Posted by SLCL
oh dear!
It's mostly parts. I'm shopping for a new tandem pump, know any sites where I can pick one up for cheap?
Old Jan 12, 2010 | 07:42 AM
SLCL's Avatar
CL55, SL500, E350
Another member got a quote from local salvage yard for over a month ago. I can ask him for you if you'd like. His quote:
"I just received an email from a local salvage yard:
$400 shipped + 3 month warrenty on a used pump."
I also see new pump sold on ebay for cheaper than dealer's price
Old Jan 12, 2010 | 02:30 PM
Gondon's Avatar
02 S500 Sport
Wow Thanx God, you got warranty on the car.
Old Jan 12, 2010 | 05:16 PM
Nightflyer's Avatar
03 CL55
ABC pump
I have an ABC pump from a CL600 if interested. not sure if it would fit a 55.
Old Jan 12, 2010 | 09:41 PM
V12TT
Gondon I don't have warranty on the CL lol. Replacing the steering rack next week. The pump seems to be OK actaully...
Old Jan 13, 2010 | 01:50 AM
Gondon's Avatar
02 S500 Sport
Damn and to know warranty would've prob cost you only 3-5k to get.
Old Jan 13, 2010 | 05:22 PM
V12TT
I tried pressuring them to cover it but apparently they said it only covers the drive train so if pistons go or the transmission gets seized then they step in. Bull ****.
Good news is I've managed to find all the parts really cheap and I already know a cert. MB tech to do the work. I still have to break my arm though.
Old Jan 13, 2010 | 07:59 PM
Gondon's Avatar
02 S500 Sport
what warranty?
Old Jan 29, 2010 | 03:37 AM
gordon harrison's Avatar
cl55 amg
Gondon:
What warranty would you advise?????? There seem to be many out there that arent worth the paper they are written on.
Benz Addict:
Lucky man.
Old Feb 19, 2010 | 06:47 PM
2003CL55AMG's Avatar
2003 cl55 amg , 2007 BMW 750 IL , 94 Viper RT , 2003 Ford F-350 7.3 ,
I would like to know if you still have that pump for sale. Please let me know and let me know the condition of it. Thank you
Old Feb 24, 2010 | 09:37 PM
Oxygen's Avatar
W220 S65 AMG
Ouch, I feel your pain. :-/
Old Feb 25, 2010 | 12:41 AM
V12TT
It's alright for now. Parked the car in the garage and swapped steering racks with a refurbished one ($800). Flushed steering fluid and all is good.
The problem was a huge crack formed on top of the steering rack that's where it was pissin out fluid like crazy. This happened at 115k miles on my car.
ABC is working well but car bounces from time to time on the drivers side.
Old Feb 25, 2010 | 10:20 AM
if it bounces form time to time.. that what it did on mine... and i took it to the dealer and when they put it on the lift ALL THE PRESSURE came out. SO make sure your not gonna put your car on a lift. i found the pump for $1,050.00 at SSF parts in phoenix arizona. The pump is brand new.
Old Feb 25, 2010 | 02:02 PM
Fraser's Avatar
A Mercedes obviously!
It is stories that like that allow me to sleep at night with my warranty.
Originally Posted by gordon harrison
Gondon:
Benz Addict:
Lucky man.
As you're in the UK you're not going to have the same options as us in the US. The Chrysler warranty is a popular one here, it is a very comprehensive exclusionary policy that doesn't break the bank. I paid $3220 for 5yrs/75k miles with a $200 excess on my S600.
Old Jul 26, 2010 | 07:29 AM
db103's Avatar
2002 CL500 (sold)
ouch
