CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
auto theft
Old Aug 18, 2013 | 09:07 AM
biker349's Avatar
cl600
auto theft
how hard are the 2004 cl's to steal? the reason i'm asking is because i had lincoln mark viii and someone broke my side window, got in the car and attempted to start it. it turned over but wouldn't start due to a cutoff switch i personally installed to the ignition coil. this saved the car. can our cars be some how jump started and what would you recommend to use with a cut off switch in our cars to prevent theft? the cl is a lot more complex.
thanks
Old Aug 18, 2013 | 09:52 AM
alx's Avatar
alx
Every car can be stolen. The version of the drive authorization for your car has been cracked long ago and there are commercial tools.
If everything else fails- a tow truck always works.
Old Aug 18, 2013 | 07:32 PM
biker349's Avatar
cl600
what would be the simplest, least technical place to run a cut off switch to?
Old Aug 18, 2013 | 08:31 PM
alx's Avatar
alx
Starter relay.
Old Aug 19, 2013 | 08:58 AM
biker349's Avatar
cl600
thanks alx, can you tell me where the starter relay would be located. also been thinking about the fuel pump. what would be the best place to hook that up as well. any advice is greatly appreciated.
