CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Front Strut Movement Question
Old Nov 29, 2015 | 10:50 PM
khutchinson22's Avatar
CL55
Should the lower part of the strut have play where it attaches to the lower control arm?
Old Nov 29, 2015 | 10:53 PM
CL55
Is there a ball joint or bushing that it supposed to be attached to because it sounds like it's metal on metal. There might be about a quarter inch of play.
Old Dec 2, 2015 | 06:30 PM
Welwynnick's Avatar
2006 S600
No.
You need a new lower control arm.
Nick
Old Dec 4, 2015 | 09:53 PM
CL55
Neither of the allen bolts want to tighten or loosen. Im afraid im going to break the allen wrench.
Old Dec 5, 2015 | 05:08 AM
Welwynnick's Avatar
2006 S600
You need to use a blow torch.
Nick
Old Dec 5, 2015 | 07:05 PM
CL55
Nick
That makes me a little nervous considering it's an ABC strut. Anything I need to know? Any risk of damage torching that part of the strut?
Old Dec 17, 2015 | 10:16 PM
CL55
Torch, manual impact, nothing wants to break these damn things loose! Im afraid to use air on it but im out of options.
Old Dec 17, 2015 | 10:21 PM
CL55
They arent reverse thread are they?
Old Dec 17, 2015 | 11:46 PM
CL55
Got em. MAP torch to the rescue!
Old Dec 18, 2015 | 07:20 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
I bet you just found the main cause of your vibration.
Old Dec 18, 2015 | 09:21 AM
CL55
Nope. Vibration remains.
Old Dec 18, 2015 | 04:47 PM
The pattern is worn into the front tires now. I would suggest you check or replace every bushing and ball joint that's not new, then grind the uneven tread off your front tires, or just buy new ones again. Then set the toe-in at less than half what is recommended. Just inside of 0. Check the wheel balance and you will run smooth for a while, depending on your treadwear rating.
Old Dec 18, 2015 | 05:18 PM
CL55
The tires are brand new. Not even 500 miles on them. With the exception of the struts, the front end is all new.
Old Dec 18, 2015 | 05:20 PM
CL55
I'm also replacing the flex discs and drive shaft support on Sunday. That should be the last of it. Although, I am hearing a bumping type sound coming from the rear over small bumps during slower driving
Old Dec 18, 2015 | 07:02 PM
Welwynnick's Avatar
2006 S600
Exhaust maybe? There are lots of hangers, and they're all pretty vulnerable to corrosion or cracking.
Old Dec 18, 2015 | 07:11 PM
It's hard to diagnose over the internet, but check your tires carefully (especially the inside edge) for tread block edges taller than other tread blocks. 500 miles was enough to do it on mine with a 240 tread wear rating.
Drive shaft support would be a totally different type of vibe, hope you get it figured.
Old Dec 19, 2015 | 10:55 AM
CL55
The symptom that makes this strange is that the vibration almost completely disappears after the car has been on a lift and then returns after a day or so. It would stand to reason that inconsistent tire wear would produce a vibration regardless of other factors. Thats what is making me think driveshaft.
Old Dec 19, 2015 | 10:57 AM
CL55
I might also mention that it has been doing this since the tires were first put on. It hasnt gotten worse or changed.
Old Dec 19, 2015 | 03:35 PM
Don't know anything about ABC, is it possible for one shock to get pulses from the pump or maybe a fluttering valve in the system. I'm just guessing wildly now, let a really good mechanic drive it.
Old Dec 19, 2015 | 05:32 PM
Welwynnick's Avatar
2006 S600
I think that's very unlikely. Hydraulic pulses are absorbed by the accumulator on the pressure regulator, and by the flexible hydraulic hoses. When one of those fails or degrades, the result is noise, rather than vibration.
In any case, internal vibration in the strut would be absorbed by the suspension spring itself.
Nick
Old Dec 28, 2015 | 05:12 PM
CL55
Nick
Thank you for that. I was questioning this myself.
Old Oct 18, 2016 | 11:58 AM
mbenz570's Avatar
C300
I didn't have to remove the bumper it is held in by clips and I was able to pull it off once I loosed it
