CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Cl55 amg transmission slipping in high gears
Old Jun 16, 2016 | 04:23 PM
Amgfan80's Avatar
2003 cl 55 amg
Ok my tranny is acting weird , at high speeds the tranny is slipping usally from 80mph to 120mph. I had the fluid checked and its fine what else could it be? Torque converter? Hopefully some.experts can help here with some suggestion. Its a 2003 cl55 with only 88k miles
Old Jul 3, 2016 | 11:47 PM
MooksM275's Avatar
W215 CL65
You really need to hook up to DAS to properly diagnose. With DAS you can view the shaft speeds and review what exactly is happening/slipping. You will also likely have codes given your saying you can feel slipping. These codes will only be available through star DAS.
Is there any strange noises?
Best
Old Jul 5, 2016 | 04:56 AM
Welwynnick's Avatar
2006 S600
Could it be that the lock up clutch isn't engaging?
Nick
Old Jul 5, 2016 | 08:20 AM
principledchiro's Avatar
2006 CL55 AMG
If Transmission Conductor Plate. Drop pan. Basically a simple swap.
