Looking to purchase 2006 CL55
Hey everyone,
I am a long time Mercedes owner, but always leased my cars; this time looking to purchase immaculate one owner 2006 CL55 with 18K miles. What issues should I be aware of outside of ABC? Looking for any advice you guys can provide... Thank you for your help! |
What a dynamic, active forum!
Appreciate all your help! ;-) |
Originally Posted by fallen
(Post 7574206)
Hey everyone,
I am a long time Mercedes owner, but always leased my cars; this time looking to purchase immaculate one owner 2006 CL55 with 18K miles. What issues should I be aware of outside of ABC? Looking for any advice you guys can provide... Thank you for your help! To me they are great highway cruisers, with comfort and power. The ABC does a great job keeping the car planted considering it's weight. Maintenance will keep the suspension performing as it should. Despite the mileage, you may need to replace ABC hoses based on age, since they may seep. My car is a weekend, good weather only car. For me, its appearance and overall feel had to remain civil. However the need for more and more power has been addicting. I've had my car for 9 1/2 years, probably more than most. It appears stock, but is a true performer. Good luck making your decision and consider an independent inspection at a reputable independent Mercedes repair shop. |
(Post 7574206)
Hey everyone,
I am a long time Mercedes owner, but always leased my cars; this time looking to purchase immaculate one owner 2006 CL55 with 18K miles. What issues should I be aware of outside of ABC? Looking for any advice you guys can provide... Thank you for your help! A 2006 with only 18K miles should be good for a few years. |
I've never had the CL55 but I do have the CL65. Besides the known ABC issues, I would check things like the hoses, flush the fluids (ABC fluid, coolant, transmission) etc. Listen for noises from the ABC pump, check the belt/pulleys/idler as they can explode. I would also check the transmission connector plug as they can leak fluid, check the brakes/pads as they are expensive to replace. See if the car sags after sitting and cycle the ABC button to make sure it rises/lowers without warning lights. Also check the tires for even wear as suspension parts like rubber bushings can dry out over time. A pre purchase inspection can also help. The car has plastic panels under that can hide potential drips.
For your car it's mainly the issues that affect any car that has sat a long time. These cars seem to like to be driven, so just make sure to push/cycle every button and listen for noises. Good luck. |
Originally Posted by WikedV12
(Post 7577404)
For your car it's mainly the issues that affect any car that has sat a long time. These cars seem to like to be driven, so just make sure to push/cycle every button and listen for noises. Good luck. Here you have an extremely low mileage car. So the first question, is that real. If it is then you could have a car that was maybe stored for a long time and that is bad. My 55 was an 05 and had 100k on it and that was considered low mileage. So you should get a PPI done and check out the service history. If there is anything wrong then run because that means the owner didn’t maintain it and, as I said, at this age the key is maintenance, not mileage. If it all checks out then buy it, as it is a very unique car. Also I am into handling and this car with the ABC system is awesome. Really no big coupe on the road today for under $200K that handles as well. If you buy it I can give you some pointers that are very inexpensive and make it handle like a Ferrari while still maintaining the great ride. Good luck |
Thank you all SO MUCH for all the feedback and great pointers - extremely helpful!
Will definitely be scheduling a PPI with the local MB dealer and keep you guys posted. @RonCL55 Looking forward to learning more about how to make the car handle better! Thank you! :) |
(Post 7578547)
Will definitely be scheduling a PPI with the local MB dealer and keep you guys posted. @RonCL55 Looking forward to learning more about how to make the car handle better! Thank you! :) The only thing I would say is I am never crazy about Mercedes-Benz dealers doing PPI’s. They will tell you there’s a zillion things wrong with it because they want to fix it at outrageous rates. So I have always steered to Independents to do my PPI’s. I noticed that you are in Los Angeles. It’s a little ways from you but I could highly recommend the mechanic that took care of my CL 55 for 10 years. He’s independent but his guys are factory trained Benz technicians and they only do Benz’s ( so not a one size fits all mechanic). He did a wonderful job maintaining my car and did what was needed but never more and was very rational about the whole car. He also knew the CL55 very well and all the potential issues and watched for them. Even if he’s too far away for you, you might want to give him a call because he’s very honest and reputable and he could probably give you a good referral. His contacts are: Five Star AutoCare (Jerry and Tony) (949) 548-6152 925 W 16th St, Newport Beach, CA 92663 |
Originally Posted by RonCL55
(Post 7578195)
Originally Posted by SmokinCummins
(Post 7578955)
You have my attention. Care to explain?
Overall the only real “cost” is lowering links ($100) and new wheels (with significantly different offsets) and tires. It is then just making suspension adjustments including changing the front scrub radius. It is actually fairly easy to do and the time involved was mostly the trial and error that I went through to get the finished product. The key is to understanding the potential of this car and then building on it. For a point of reference, here is a link to an old Car and Driver article that compares a CL Mercedes, a Ferrari, an Aston Martin and a Bentley back in 2005. https://www.caranddriver.com/reviews...mparison-tests So Car and Driver recognized the CL as a world class GT car and in commenting on the ABC system they said: "Then there's the semiactive hydraulic suspension. It's a system of sensors and computer-controlled hydraulic rams and shocks at all four corners. It can instantly adjust from cushy soft for soaking up bumps to sports-car stiff to reduce body lean in corners. It's not perfect--some abrupt freeway impacts send jitters through the body--but in general, it works fantastically. The CL digs into corners with a surprising amount of bite and enthusiasm. One tester wrote, "Wow, very impressive in the turns, feels almost as agile and frisky as the Ferrari." I owned my CL when I first read that article and found it inspiring and actually went out and bought the Ferrari used in the article (I thought it was neat to own at the same time the top 2 GT cars in the world based on that article—don’t worry I bought them both used and each for about 1/3rd of the original sticker, so not rolling in the dough here). I then did my own little comparison test as it were. I found that while the CL did handle well from a technical standpoint, it was “soft” and did not have the “tight” handling feel of the Ferrari. So like Steve Austin, I thought I could “make her better”. I worked with my mechanic and over the years I experimented with wheels and tires and minor suspension adjustments and ended up with a CL that handled every bit as well as my Ferrari in the corners and had that “tight, on the rails” feeling of the Ferrari but still had the overall ride and comfort of the factory CL. When I was finished I actually thought the overall ride and handling of the CL was better than the Ferrari. The key is there were no physical changes to the car, just relatively low cost bolt on things and adjustments. So anybody can do it if they want to. In my humble opinion my CL55 was the best car I have ever owned when you factor all together acceleration, ride, handling, comfort, looks and reliability. Unfortunately I no longer own it and I do miss it. So back to the OP’s original question, if the car checks out, you should buy it! |
I look forward to it. I love the way my CL65 drives, but upgrades are always nice.
(Post 7578955)
Good luck! |
