CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Preventive Maintenance
Old Nov 16, 2020 | 12:40 AM
abdoulwane's Avatar
93 S600 Coupe AMG; 98 CL600; 96 S600: 05 CL65 AMG; 71 280se 3.5; 89 560SEC. 84 500SEC AMG;
Hi all
I am the proud owner of a CL65. I wish to obtain a very PRECISE advice of what preventive maintenance items should be addressed at what interval to keep maintain longevity of this car (Aside from frequent oil change -- and topping up )
Thank you.
Old Nov 16, 2020 | 12:50 AM
MartinWake's Avatar
CL55
ABC filter, ABC accumulators. Not sure how often. Post some pics of the car
Old Nov 16, 2020 | 02:39 AM
abdoulwane's Avatar
Old Nov 19, 2020 | 01:16 AM
the_indian_kid's Avatar
2008 MB C350 4MATIC/2011 CL63 AMG/2014 C63 Coupe 507
Wow such a beaut; i have an m157 CL 63 2011, and was told atleast every 3 to 4 years abc fluid swap wouldn't hurt; and biggest thing, apparently, is not to have the car sitting for soo long as over time it can dry out the ABC lines. This is what i have been told, and does make sense to me. Hope this helps. Enjoy the screaming 12
Old Nov 21, 2020 | 12:06 PM
MBZFAN55's Avatar
BMW M850i Gran Coupe
Changing the ABC fluid is not a bad idea especially if the CL is not driven regularly. My 2008 CL63 has 35k miles and I never let it sit too long just to avoid sedentary issues like ABC line & pump failure.
2008 CL63 P30 Performance Package
Old Nov 23, 2020 | 07:51 PM
abdoulwane's Avatar
What an EYETREAT !!!!!
Old Nov 23, 2020 | 07:54 PM
abdoulwane's Avatar
I thought I'd share this... (from Brian @ FCP Euro)
I would recommend fluid changes and flushes as needed, including servicing the transmission filter and fluid and we offer kits for this.
https://www.fcpeuro.com/Mercedes~Ben...0Service%20Kit
The belt and rollers should be looked at https://www.fcpeuro.com/products/mer...ntitech-517605
You should also check the filters:
https://www.fcpeuro.com/products/mer...-w230-042-1695
https://www.fcpeuro.com/products/mer...it-mann-210830
https://www.fcpeuro.com/products/mer...mer-0024775701
Old Nov 23, 2020 | 09:31 PM
abdoulwane's Avatar
Any recommended brand for ABC fluid? Pentosin too?
Old Nov 29, 2020 | 06:55 PM
JustTXn's Avatar
2005 CL55 AMG || 2005 CL65 AMG || 1989 560SEC
Pentosin is good, doubly so since you can just buy it at a parts store... Opinion varies on intervals, but I've decided to change mine every 40k miles. ABC fluid is hygroscopic, much like brake fluid. If your car tends to wander over bumps while you're turning, consider changing lower control arms (or just bushings).
Engine mounts are fluid filled and fail relatively often, which then exposes oil lines and ABC lines to excess movement from the engine moving more than intended, leading to accelerated wear/destroyed lines.
Old Feb 2, 2021 | 12:01 AM
Vahebaldemian's Avatar
2009 CL63 AMG (CL55 AMG Kompressor previous vehicle)
CL
I had a 2003 CL55...just flushed the abc fluid every amd then. That car never sent me or itself to the shop. Only at 80k did the ABC pump give out. Now i have a CL63 and i feel like ive already rebuilt the car. And i misssss my CL55. I enjoyed driving it way more than the 63.
Old Feb 5, 2021 | 06:54 PM
superveloche's Avatar
2007 SL55 P030, 2005 CL55 AMG
Hey Guy's. It does not matter what ABC oil you choose, Pentosin, Febi, Swag, Mannol etc. as long as the oil has the MB approval code 345.0. This is the only suitable oil for the ABC systems.
Old Feb 17, 2021 | 01:07 PM
Welwynnick's Avatar
2006 S600
If anyone wants to know all about preventative maintenance they should definitely read Howard's legendary thread here:
https://mbworld.org/forums/s-class-w...2003-s600.html
Nick
