CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Third Brake Light help!
Old Mar 14, 2021 | 03:09 PM
TP_cl55's Avatar
CL55 AMG
In the middle of doing a third brake light replacement, it was cracked and letting water into the trunk. I’ve taken the liner out and removed the old housing from the trunk lid but I cannot get the old clip that connects to the lights off for the life of me! And on top of that, where the light is located I can’t wrap my head around actually getting it in and out. Is there a special tool Mercedes uses to unclip these connections?
Old Mar 24, 2021 | 10:31 PM
JustTXn's Avatar
2005 CL55 AMG || 2005 CL65 AMG || 1989 560SEC
Not sure how to remove the connector, but while you're in there you should epoxy the seams of the vacuum actuator for the latch, because they generally all crack or leak eventually.
