SRS Warning Light...........
03CL55, 07BMW 328XI Coupe
My SRS steering column module was replaced 3 x's three weeks in a row, every time I drive my car home the next day the SRS warning light is back on.
This is a very common problem. the cause of the problem has got nothing to do with the module. the problem is that there is toomuch flow of electricity in to the airbag squib wiring loom. mercedes have a modified cable harness with some plug connectors which have to be soldered in. the cable isnt much money which is arond 20-30 dollars. hope this helps.
