CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
How do I know if my ABC broke?
Old Sep 1, 2012 | 07:20 PM
Guilty's Avatar
'16 C63-S
Hi,
I was driving the car a little hard today and when I was stopping at the red light I heard some weird noises coming from what I believe is the right front tire... I parked the car when I got home, let it rest for few hours and when I came back same thing. I raised the car up using the button on the dash and dropped it again... Everything seemed to be fine except that awkward noises I kept hearing.
I parked the car again if front on my building and called this guy who owns like 200 cars and asked him for some help since everything is closed. He looked at the car and he told me that he doesn't even need to drive it, it's hydraulic problem. He said that because he noticed the car is unlevel. I took a look at my rear right tire and I also noticed that he dropped is uneven compared to the front...
He told me don't drive the car and call him tomorrow he can get me a good deal... I still don't know what's up with the car... I hit the button to raise the car up again, then dropped it and it looks fine (I repeated that operation many times)
Does this ever happened to anyone here? Is it the ABC? Am I supposed to see a light coming on the screen and tell me don't drive the car?
Some help would be appreciated because this isn't an easy fix and my car just got out of warranty last week
Old Sep 1, 2012 | 08:18 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
number of things can go wrong in the ABC system. If it just ran out of warranty last week and you know the SA adviser at MB, they may fix it under goodwill.
Old Sep 1, 2012 | 08:23 PM
alx's Avatar
alx
They sit lopsided every now and then. Leave the car for a few days and see if she loses height at one or more corners.
Abc malfunctions usually are announced to the driver. The only piece in the abc that can make noise when broken is the tandem pump in which case you will know beyond doubt that something is wrong as the car will be undriveable.
"cutting you a good deal" sounds like he will sell you some blinker fluid at great discount.
If you still believe you might have a problem (which you might)- have the car read with das and take it from there.
Old Sep 2, 2012 | 07:52 AM
Guilty's Avatar
'16 C63-S
alx, when you say leave the car for few days, you mean don't drive it?
Old Sep 2, 2012 | 10:46 AM
biker349's Avatar
cl600
i believe he means don't drive it. i would also check your fluid level. normally you will get a warning light if there is a problem with the sytem. it also might be a loose strutt. i've read where the front strutts sometimes loosen up and cause noise. good luck and don't fix without proof and a valid diagnosis.
Old Sep 2, 2012 | 11:34 AM
Guilty's Avatar
'16 C63-S
Guys, I went for a 10 miles drive to get breakfast this morning. I still hear that weird noise. I'm ashamed to admit it but I don't understand much about mechanic (I'm young, haven't had much incidents)
It's my only car so letting it stay in the garage for few days is not an option, I have to go to school/work every day.
I took some pictures, maybe you guys can see something I can't see.
PS: I know I need new brakes and wheels. Just waiting for some money to come-in before I can go ahead and order the lot.
PS2: If there is anyone in the Miami area who's good with cars and willing to help me figure out what's wrong with my toy, please let me know. I will come to you.
Old Sep 2, 2012 | 02:33 PM
alx's Avatar
alx
Jut drive the darn thing...
If you are still curious if you have a problem take the car to a dealer and have it read and checked out for a couple hundred bucks.
Old Sep 3, 2012 | 03:49 AM
SnoopSER's Avatar
Your Mom Krazy
Your tires look low....TPMS not working either??
Old Sep 3, 2012 | 08:16 AM
Guilty's Avatar
'16 C63-S
No, my tires are fine. TPMS is working.
Old Sep 5, 2012 | 12:47 AM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
I'm thinking the ABC pump is on its way out?
Old Sep 5, 2012 | 01:17 AM
Rich8's Avatar
2003 CL 55
Go to JsBenz in Miami .... Ask for Jr ....
Old Sep 5, 2012 | 07:03 AM
Guilty's Avatar
'16 C63-S
JsBenz sucks. They put aftermarket air filters in my car and wanted to charge me OEM price (even more expensive than OEM). They dealt with bad faith with me and didn't properly serviced my car.
Old Sep 5, 2012 | 03:12 PM
RPB's Avatar
RPB
ABC again, I am so sick of hearing about this problem on the newer MB's and it reminds me of the old Range Rover air suspension, its plagued. This is not a good every day driver to rely on my friend, if so go buy an old MB for backup. You will not have to deal with these type of problems. They are very temperamental these days lets be realistic here. Very aesthetically pleasing yes and fast when everything is working. Too many gadgets and the car is confused.
GL w/ the issue.
Old Sep 5, 2012 | 04:31 PM
Guilty's Avatar
'16 C63-S
Yeah I'm seriously considering buying another DD. I'm putting too many miles in the CL. But then.. I'm gonna have a parking problem...
Good news is that it's not the ABC that broke. That's what my SA sent me:
"Yes, they found the ABC system to be fine but found some under voltage codes. They are currently test driving the car to see if the codes will come up in the system again. In reference to the noise you heard it is a ball joint on the left front suspension that is making sound when turning. I will provide you with an estimate for that shortly."
I was just visiting the dealership, they're still trying to figure out what are the voltage codes. I don't know how much the repair is going to be yet.
I'm also gonna ask them to flush the ABC fluid and replace the filter just for a piece of mind.
In two weeks the car will go back to the dealer for a brake-job + service B.
I'm done with dealing with indy shops, it's not worth the headache. I figured that if I drove a CL63, I might as well stop being cheap and take care of her properly and accept to pay the "Mercedes tax".
Old Sep 5, 2012 | 06:16 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Find a better indie mechanic. Mine is better than the dealers locally.
R.K.
Old Sep 5, 2012 | 07:34 PM
biker349's Avatar
cl600
glad you got it figured out.
Old Sep 6, 2012 | 12:26 AM
Rich8's Avatar
2003 CL 55
Sorry to hear that !!! I have had great luck with JsBenz !
Old Sep 6, 2012 | 05:53 AM
MBFLO's Avatar
2001 E55 - 2008 CLS63 -2016 F-150
CL63 and no warrenty >? ouch
Old Sep 6, 2012 | 09:04 AM
Guilty's Avatar
'16 C63-S
Guys, just received the estimate from the dealer:
The labor seems a little high?
Old Sep 6, 2012 | 11:07 AM
bimerbenzbently's Avatar
CL55 AMG/S55 AMG
control arms are time consuming, i think thats not that bad though
Old Sep 6, 2012 | 02:25 PM
Guilty's Avatar
'16 C63-S
I gave them the green light, my car should be ready tomorrow. I told them to not do the alignment though, $300! I'm gonna have it done somewhere else, but do I really need it?
Old Sep 6, 2012 | 04:44 PM
awiner's Avatar
2003 CL55 AMG
Yes, if they are replacing the control arm bushings, the control arms need to come out which means an alignment is necessary.
Old Sep 6, 2012 | 06:36 PM
Guilty's Avatar
'16 C63-S
Car is ready! Picking it up tomorrow!!
Old Sep 6, 2012 | 07:20 PM
alx's Avatar
alx
... You know that none of the repairs listed here addresses noise that you might have heard while stopped, right?
Old Sep 6, 2012 | 07:26 PM
Guilty's Avatar
'16 C63-S
The car made noise from the front left wheel while I was turning/stopping
