Cooling fan not working
2004 CL55 AMG Kompressor
Hello everyone, I hope somebody can help me with this one.
I just bought a 2004 CL55 AMG Kompressor with 48k miles. The car had minor damage in the front but was bad enough to break the cooling fan. Long story short, I bought all the parts including a used OEM fan, and decided that might as well change the water pump/thermostat and A/C compressor. I Put everything in place and started the car today. Everything sounds good but the fan refuses to come on and I'm getting a "Coolant Visit Shop" error message.
It seems that the thermostat has opened and the water is circulating because I have heat. The temperature goes up to about 100 degrees, still nothing. I checked some fuses under the hood, passenger side of dashboard and behind passenger seat. Not sure exactly which is the fan fuse or relay because the car came without a manual and Mitchell On Demand does not have a wiring diagram available.
I scanned the system and came up with a P2073-02 code.
Any ideas?
Any ideas?
Super Moderator
P2073 is definitely a fan related error. (Electric suction fan for engine or air conditioning).
Have you checked all wiring and the associated wiring harness ?
Can you put 12V to the fan and see if it operates independently ?
See: https://mbworld.org/forums/c-class-w...-workshop.html
Do you know which fuse and relay are related to the fan and the exact location of them? The fuse box cover does not have a diagram and Mitchell On Demand is no help on the vehicle.
Another thing I've noticed is that my A/C is not coming on. It's gotta be related.
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
On mine..
Dealer replaced entire cooling Fan Assy....about 1200 bucks. AC compressor shut down also.
Ok so it was a bad cooling fan..
Bought a new one from Mitch's Auto in MI. Cost me $570 shipped and I'm back in business..
I'm loving my car so far. Great car to have after my BMW E60.
I did have to replace the transmission mount because I was getting noticeable vibration at 3000RPM and that took care of the problem. Now i have to figure out my Pneumatic problems!!
Thanks everyone for your help.
I am serious. I wont let anyone touch my car. I did the entire front end and the SRS/seat belt system. I have a few scanners but nothing specific MB. How much is DAS and where did you get it from?
