2001 CL600 starter relay
CL600
The starter does not crank, I changed the batteries on the key because I was having problems with the controls and that issue was resolved. It still is not cranking and not a single click or any other noise when I turn the key. I would like to make sure it is not something else, since it is not so easy to change the starter. I was told that it could be the starter relay or hella, whatever that means. Does anybody know where it is located, I looked at the fuse location diagram and I do not see anything related to the starter, I'm hoping it is not the P/N switch either. Thank you for all the replies. HAPPY HOLIDAYS
