CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
HOW TO: (*Videos) Change + upgrade 3micron ABC Filter + check & correct fluid level.
Old Jan 10, 2013 | 09:54 PM
nidyanazo's Avatar
550HP+ ///AMG CL55 Kompressor, Ducati 916bp, Yamaha R1 WSBK replica
Exclamation HOW TO: (*Videos) Change + upgrade 3micron ABC Filter + check & correct fluid level.
Today I'm showing how to Change your ABC system 10mircon (stock filter) to the upgraded, better filtering 3 micron filter.
Also going over checking and fluid level adding procedure.
First, here's the parts you need:
And here's how to do it.
Make sure to first take a look here:
Video to change filter:
---> If you are just doing a Fluid level check/correction
1) Park car on a LEVEL surface
2) Start engine.
3) Press the ABC button until 2 red lights are on, and car is in the utmost raised position.
4) Lower it so both lights are out.
5) repeat steps 3 and 4 again.
6) Switch off engine.
7) Wait 5 minutes before proceeding for levels to stabilize.
8) CLEAN outside area around the and cap and dipstick.
9) Remove dipstick and wipe with lint free cloth.
10) Put the dipstick back into the fluid expansion reservoir.
11) Remove the dipstick and read the fluid level by looking at the side of the dipstick that says "ENGINE OFF UNLADEN"
*FLUID MUSH BE BETWEEN MIN AND MAX.
12) If needed, correct the fluid level.
In these steps it says to unload the car.. I'm assuming it means to remove any persons and luggage that could add weight. It would be quite impractical to have to unload the weight from off of the wheels by raising the car on a lift.
Can anyone confirm?
Old Jan 11, 2013 | 09:58 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
nice videos you are posting
Old Jan 11, 2013 | 11:55 AM
alx's Avatar
alx
Can anyone confirm?
correct. the procedure calls for the vehicle to be empty, but on the ground.
Old Jan 11, 2013 | 01:32 PM
awiner's Avatar
2003 CL55 AMG
I keep my level about the same as your was.
I once filled up to the top mark and had a huge clean up when the ABC system pressurized, engine got turned off and the excess fluid was sprayed out the tiny vent hole located in the rear of the rubber dip stick top.
Since then, I've always run the level about a 1/4" lower than full unladen.
Old Jan 11, 2013 | 03:22 PM
nidyanazo's Avatar
Thanks bro!
Good to hear. Thanks for verifying. For a minute I was thinking unladen suspension by taking all weight off the wheels.
Interesting. I'll update if I have that happen. Good to get as much info as possible, so thanks.
