CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Battery going flat after it rains
Old 07-24-2013, 10:08 AM
stu2020's Avatar
CLK55 AMG 2003 (W209)
Hi,
I have a problem with my 2003 CLK55 AMG battery going flat when it rain. I didn't initially associate it with the rain so first replaced the battery as I didn't know how old the original was. This didn't work.
I then took it to an auto electrician and they did a diagnostic test and found a fault on the alarm sounder - this I replaced (total of £470 for diagnostic, parts, labour & vat - is that expensive?). This didn't fix the battery going flat problem - but I now have a working alarm!
I can not use the car for 1.5 weeks with no rain and it will start fine. If it rains heavily for a few hours and I don't use the car the battery is completely flat (can't even open the doors).
Is there anything/anywhere I can check for water leakage or do I have to take it to the auto electrician again and check for current drain whilst hosing the car down! Are there any common areas affected by rain?
Any help appreciated - of all the niggling faults on the car this is a real show-stopper.
Stuart
Old 07-24-2013, 11:23 AM
alx
alx's Avatar
Change the bloody country. Across the channel are some sunnier ones.
... And then change the forum you posted this...
Old 07-24-2013, 12:06 PM
stu2020's Avatar
Ah - it's been a long day - I'll re-post in the right area :-)
Quick Reply: Battery going flat after it rains
