ABC....again.... any ideas?
I have gotten the dreaded red error message a few times. It goes away after I shut off and restart the car.
No leaks, fluid level OK.
Scanned with my SDS and it shows errors for all accelerometers, pressure switch, and all strut travel sensors. I cleared the codes, drove the car and they all came back a few days later when I got the red message again.
Cleared them again and put it in rodeo mode. After just a few minutes it stopped rodeoing on it's own and then popped up with a communication error message, but no fault codes.....
Lowest pressure I saw during the rodeo was 157 bar.
No recent work on the car other than trans conductor plate a couple months ago.
Going to try and unplug then re-plug in the ABC module looking close at the connections, any other ideas?????
Oh, and it seems to happen after I get on the throttle , not just while cruising. Worried it may screw up my racing on Labor Day if I don't figure it out.
Maybe a ground issue? could you have disturbed a ground during some of the previous work to the car? Grounds can be nasty, rearing their head at times you would not expect.
Possible, but no grounds were touched in a very long time, at least over a year. Drove the car a lot last two days and it hasn't come back ......yet.
Never saw the voltage drop below 12.2 when I was scanning the car with my SDS, but that was with the car off. I have not been watching it otherwise. I'll keep an eye on it today when I drive the car.
Have you done the accumulators yet?
For me a couple years ago, got the Red Message, ordered the accumulators, drained ABC, swapped out the accumulators, refilled (new filters)... Message gone.
I inspected the accumulators(removed) and one of them the membrane inside broke..I think they all eventually break...
I did all 4 (accumulators & pulsation dampener) a few years and about 20,000 miles ago the first time my HPE hose blew. It literally popped in my driveway and I shut the car off long before much of the fluid ran out. Replaced every hose that had any sign of a fluid leak. Also flushed system and replaced the filter then, and again about 1-1/2 years ago when I put in a new front valve block.
My rear valve block is bleeding down intermittently now though so still have that to deal with, but I do not believe that is related at all.
Totally agree. I never have and never will run a car that has an issue. I will only race if the issue is resolved, but I really want to run one more weekend before I retire the CL from the track!
Even if the car isn't right I'll still be at the track as I'm going to use a friends 8 second open air car to qualify for a higher level license. Should be fun running 150mph in a T-bucket! Just need to loose a few more pounds as her pants are pretty tight for me to get in, lol.
The steering went completely dead and you couldn't move it. When one hydraulic system goes then the whole car is dangerous.
I think we may have a winner here......
Checked the battery this morning. Due to location of the battery, one of the mods I have done is a quick disconnect at the positive terminal of the battery, and sure enough it was loose. Really loose.
I'm normally pretty meticulous (my wife, kid, friends, etc. use a different word) so to find that loose when I checked it was a shocker. It was loose enough I'm actually surprised the car even had enough of a connection to start.
I'll keep driving the car and see if the issue comes back., no way to know until it doesn't return over time.
