Fuse for Multi-Contour Seat Control and Pulse Function?
New to my 01 Cl55 AMG. Everything works but cannot get either the buttons that control the air bladders in the seat, nor the Pulse (light does not go on) functions working. Harness that goes to the switches seems good. Don't know if that is a separate fuse or combined with another electrical function. In any case, can't find a fuse box(s) diagram to locate it. I have this:
http://www.autogenius.info/mercedes-...e-box-diagram/
but it did not show it.
On my 06 CLS 55 the dynamic seat fuse is in the trunk. Left side, just start ohming them out or use a test light for voltage on both sides of the fuse. I had a bad circuit board for the pump, but the motor was good.
Rpkxnoscope (10-30-2019)
thanks for the suggestion. yeah on the cl55 there are no trunk fuses but rather a det under the rear seat passenger side. will look at that array as logically it may be in that location.
