keeping transmission alive 2005 cl65
I remember reading Mercedes limits the torque on my 2005 cl65 to save the transmission. I always thought the torque curve would be a flat plateau, not much of a curve (I'll find out what it looks like for real, more on that later). I am going to do "stage 1." Since I have found very little support for these cars, my stage 1 will be a simple intake like I've seen here, resonator delete, maybe water/meth and a dyno tune at AMR. My question is what have you all done to keep your transmission alive with a stage 1 power increase? What would be needed for a stage 2, which involves downpipes, turbo, and more tuning?
Thanks all
Thanks all
i think all benz cars of this era has a torque limiter, whether it was 15% or what i cannot remember
enable dyno mode and i believe the torque is de-limited. plenty of people add power to these cars and there doesn't seem to be common complaints of transmission failure etc. the 722.6 i believe you have, is largely robust
i know of one mod where the transmission oil pan can be enlarged, made of billet and has a sort of heatsink design built in. its designed for high HP applications
i would also consider adding a dedicated tranny cooler. they say heat is the biggest enemy of transmissions. hell, i'm even considereding adding an aux tranny cooler to my 360~hp cl55 swap because why not. I plan to keep this car for a long time and have no other use for this ABC radiator i no longer need
just expect to need a tranny rebuild sooner with than normal , with more power, for example. after 100k miles or so i consider this to be considered part of maintenance anyways.
