Vivid Racing -- Eventuri CLA45 AMG Black Carbon Intake System
Are you looking to add some character to your engine bay, while also freeing up some additional airflow and horsepower?
You're in luck! Vivid Racing here, presenting an incredible intake system from our friends at Eventuri, their Carbon Fiber Intake System!
In Stock!! Price: $1,495.00 (Free Shipping to Lower 48)
Why Choose Eventuri?!
The Mercedes M139 intake for the A45 and CLA45 has been developed to allow the turbo a smoother route for airflow to be drawn from. By redesigning the system to allow for a much more direct path, the turbo is able to generate boost with less drag and therefore reach target boost pressure sooner in the RPM range. This intake system has been developed to offer the highest possible flow rate whilst maintaining the lowest intake temperatures possible to produce a net performance gain. The de-restricted flow path also allows for turbo spool to be heard more clearly adding to the dynamics of the overall driving experience.
The AMG M139 Eventuri system uses our Patented Carbon Fiber Housings with our Gen 2 bespoke filter, which provide an aerodynamically efficient airflow path from the filter to the turbos. Not just another cone filter with a heat shield but a unique design which invokes the Venturi affect and maintains laminar flow conditions to reduce the drag on the turbo.
Features!
Performance Increase : 15-18hp, 12-16ft-lb
Carbon Fiber Patented Venturi Filter Housing
Bespoke High Flow Dry Cone Filter
Carbon Fiber Inlet Duct
Laser Cut Stainless Steel Brackets
Laser Cut Stainless Steel ECU Relocation Mount and Cover
Silicon Coupler with OEM Specification Clamps
Questions? Connect with the team!
forums@vividracing.com
(480) 966-3040
Direct Email @
tristans@vividracing.com
Extension 239
We can't wait to hear from you!
Tristan Shallow
Vivid Racing
Performance Specialist
(480) 966-3040
