Bluetooth Audio
I've a problem with trying to connect my Samsung Galaxy S5 to the Bluetooth Audio,just keeps saying phone not found, I can make calls etc,help!
Make sure your phone's Bluetooth is in search mode. Its usually a small checkbox on your phones Bluetooth screen where which would allow other devices to connect to it. Also try these steps below:
Turn Bluetooth On and Off Enabling Bluetooth on your device is simple: From a Home screen, tap Apps > Settings. Tap Bluetooth, and then tap ON/OFF to turn Bluetooth on or off. The notification panel also provides quick access to the Bluetooth function, allowing you to quickly turn it on or off. Simply swipe down on the Status Bar to display the Notification Panel and tap Bluetooth to turn it on or off. Make Your Device Visible to Other Bluetooth Devices When you make your phone visible, other Bluetooth devices can find it in a scan and initiate pairing. You can choose the length of time your device remains visible: From a Home screen, tap Apps > Settings. Tap Bluetooth > More options > Visibility timeout. Select a time period for your device to remain visible after you turn on visibility. Scan for Bluetooth Devices When you want to pair with another Bluetooth device, you can scan for nearby devices that are visible. From a Home screen, tap Apps > Settings. Tap Bluetooth, and then tap the ON/OFF switch to turn on Bluetooth. Tap Scan. Nearby devices will display on the screen. Pair Bluetooth Devices The Bluetooth pairing process allows you to establish trusted connections between your phone and another Bluetooth device. Pairing between two Bluetooth devices is a one-time process. Once a pairing is created, the devices will continue to recognize their partnership and exchange information without having to re-enter a passcode.
