Let me lighten the load!
Former Vendor of MBWorld
1 Post
E63 AMG
Hi all just a quick post to let you into some of our upcoming products. All of our products are fully road and race tested.. to give you some idea our A45 is a year old and has 31k Miles on the clock and we have more than one 45 AMG in testing at any one time !
From finding the limit in testing and buying new engines!
To strengthened Turbos
We strive to build the best products at reasonable prices
These are still in development so all details will be released in due course
1. Lightweight Forged Wheels (18 x 8.5 and 19.8.5)
With these we have machined them exactly for the 45AMG platform taking into consideration ET's, max weight saving and maximum strength.
here is a teaser.
2. Silicon Carbide Ceramic Rotor Upgrade
These are direct bolt replacement Rotors with matching Pads for the Stock Calipers, Will give a massive increase in Disc and Pad life with no brake dust !!
Changing Rotors will save 30KGs (66lbs) of Unsprung Mass
Adding our light weight Calipers makes a total saving of 45KGs (100lbs!!) of Unsprung Mass.
Our calipers here with our lightweight Steel Rotors. Better braking with direct pad cooling ducts .. Carbon of course !
3. Additional Charge Cooler Radiators
These are direct bolt, add more coolant to the system and help maintain intake temperatures
4. Light Weight Switching Exhaust System
Will post up a few more projects once we are close to release
Cheers from us at TeamRebellion
Any questions just shout !!
here is a teaser.
Also interested in this as well Matt. VERY impressive weight savings. How is the performance of these rotors compared to stock?
That exhaust you have pictured, assuming this will be sold as the picture entails with no midpipe or downpipe included? I have been waiting anxiously for someone to sell an exhaust like this that doesn't require you to buy the entire 'turboback exhaust'. This appears to be simply a 'muffler' swap as such, am I correct?
If this is priced reasonably, you can sign me up will be looking forward to the sound clips!!
EDIT: Matt, can you also confirm if that exhaust will retain the OEM 'quad' tips as well? Just noticing how the exits on your exhaust seem to be flared outwards, so I am wondering if they still fit fine with the OEM tips.
1 Post
E63 AMG
Hi Guys,
Will post up prices for the Ceramic Rotors later today, yes full front and rear.
Yes the exhaust is modular so you can leave the stock downpipe and mid pipe in place and just have the rear section. We have designed it to be fully bolt in bolt out with oem fixings. That means you can always upgrade later on if you wanted to our Sports Cat Downpipe etc.
Yes the tips will fit into the stock tips in the bumper so no need to change anything
Cheers,
Cheers,
Mercedes C200 CGI, CLS350, CLA45 AMG, AMG GTS(ordered)
While the front rotors will save around 15kgs over the OEMs, the rear OEMs are only half the weight of the fronts. So actually weight savings will be around 22kgs instead of 30kgs. Still nice though.
From the pictures you will be using shorter brake pads with the OEM calipers. The stock pads are 71mm high. The sweep area will be less than OEM.
Nice looking muffler. Depending on the sound and the weight savings over stock, I may have to abandon my plans for a custom titanium catback.
1 Post
E63 AMG
our pads are shorter but wider so better bite, more braking force and better for cooling.
Also front set-up would be 388mm or 360mm disk so more of the pad is further out on the disk giving better braking efficiency
1 Post
E63 AMG
Yes Brackets, Brake lines, Calipers, Bolts, Pads and discs are all included in our kits
No our Ceramic or 360mm Upgrade system allow you to use 18inch rims
Great news with the exhaust! When you mention 'switching' exhaust, am I right in assuming that it will operate like the OEM exhaust with the butterfly valve? Or does your exhaust incorporate an electronically remote controlled valve?
If it has the mechanically actuated valve, will the system behave similarly to the OEM exhaust such that it keeps the valve closed and quiet in C mode, but allows it to open sooner in M and S modes?
And obviously the most important question, when can we expect some sound clips!?!?
Thanks,
Justin
Matt can chime to confirm if that's correct
EDIT:
Actually, it looks like you may be correct as it seems they offer both ceramic and steel rotors. Matt, can you chime in on the performance of both styles versus stock? And can the steel rotors (if they are the better performer) be used in conjunction with the OEM calipers?
1 Post
E63 AMG
Ceramic Rotors are 350mm and use OEM Sized Ceramic pads matched to the stock Caliper.
Our Braking system uses narrow rotors further our so the actual calliper grabs at the furtherest point, so more of the pad is in an effective grab area. These are 6 piston calipers too rather than 4.
Yes our 360mm kit will out perform the stock units like day and night !
EDIT
We can also add ceramic discs to our setup for the ultimate brake setup.
EDIT
1 Post
E63 AMG
Ceramic Rotors can be made for any car and will match to the stock rotors so no problem there.
Our style rotors will only work with our our Calipers as they are matched to the pad size to be effective. We supply fitting brackets for any car so no matter the car our kit will fit
EDIT
EDIT
Most importantly is the exhaust rhough!! Please see my earlier post Matt regarding my exhaust questions! I could also email you as well if it would be easier for you!?
Justin
1 Post
E63 AMG
Our best matched Braking system comprises of the following..
Front - New 6 Piston Front Caliper, 360mm Lightweight 2 piece steel Discs with braided stainless brake lines
Rear - New 4 Piston Rear Caliper, 335mm Lightweight 2 Piece steel Discs with Braided stainless brake lines
This will give a 22kg (45lb) Weight Saving, Better Clamping force, better Braking feel, better braking distribution, Better disc and pad life.
The best bit about it is when you sell your car you can take the brakes with you and fit to your next car
Cost for this is
Front - £1849 GBP
Rear - £1769 GBP
This includes all brake lines, Bolts, Brackets, Calipers, Rotors and Pads. Its fully direct bolt so no modifications needed.
Right Exhaust !
As you all know we have a Downpipe and mid pipe solution already (including a sports cat version)
The rear section has been in testing for over half a year and we are almost ready to release.
It is remote switching with our machined Valves, no weld in rubbish .. just well engineered components.
Our system has 2 complete paths through the rear box so no matter loud or quiet you will get no performance loss. This allows you to drive in sport or Manual mode without having it in loud mode unlike the standard system.
The rear section matches up to the stock mid pipe so no need to replace the down pipe etc.
Here you can see the stock crushed pipes.
Here a video of it in Loud
https://www.youtube.com/watch?v=zMr2...ature=youtu.be
Exhaust will retail for £1499 GBP ($2199)
Cost for this is
Front - £1849 GBP
Rear - £1769 GBP
Right Exhaust !
Hi Matt,
Just to clarify a few other things.
Your front rotors save 9kgs total over stock. Since the stock rears weigh only about half as much as the fronts you will save around 5kgs. So the calipers save 8kgs?
Is the soundclip with stock or decatted downpipe?
The stock exhaust weighs around 21.5 kgs from the midpipe back. Could you please check the weight of the corresponding sections from your exhaust.
Thanks.
This is getting very interesting.
Thanks.
1 Post
E63 AMG
Yes correct calipers save 8KG
Sound is with Stock Downpipe
Will weigh the sections for you, there is a good weight saving there though
Do you want me to weigh the Down pipe weight saving too ?
Interested in this as well; if it is for just the rear section I am afraid it will be out of my price range. That is near $2800 CAD before shipping or customs charges for a muffler which puts it out of my range, seeing as I just got engaged... The better half would kill me haha
If that price is for the full exhaust, a detailed price breakdown would be superb Matt!
By the way, sound clip was nice, but do you have any videos of the exhaust under load!? Or perhaps with someone revving the car who is a little more relaxed? Haha
