CLA 45 AMG (C117) 2013 to 2018
▀▄ Winn Autosports ▀▄ | RENNtech performance upgrades
Old 08-28-2017, 08:16 PM
Former Vendor of MBWorld
winnautosports's Avatar
AMG GTS, E92 M3
RENNtech's Boost pressure gauge.
RENNtech's Boost pressure gauge offers direct visual indication of your CLA's turbo performance and available boost pressure. Our easy to ready, 67mm gauge faces features an attractive carbon composite look and mounts directly into your CLA dash without cutting or drilling. RENNtech's boost gauge features an internal microprocessor which controls the pointer (needle) movement and a digital high torque stepper motor to ensure quick, accurate pointer movements. The state of the art internals also control unwanted pointer movement or needle float found in other gauges on the market even under the most extreme motorsport conditions.
The gauge is available in both PSI and BAR readings with large, easy to read numbers in all lighting conditions and features a white illuminated background for low lighting. Settable warning LED is also available with settings for both Low and high conditions. The gauge is finished off with a stylish aluminum bezel and comes complete with all necessary line and fittings for installation. Custom colors and scales are also available.
The RENNtech Stage I Turbo Upgrade comes with an ECU upgrade and performance air filter
Entire cartridge is fine balanced as an assembly
Lightweight forged billet wheel
Modified bearing and strong shaft
Less rolling resistance offers quicker spooling
Virtually no lag with impressive throttle response
Up to 460 HP and 415 TQ @ crank
Notes:
This Turbo Upgrade requires an additional core charge, which will be credited upon return of OEM turbo core to RENNtech
We have found the new M133 engine stock performance numbers vary from the baseline figures claimed by Mercedes Benz. We typically see slightly higher baseline numbers than claimed by the factory. Numbers will be dependent on conditions and fuel quality.
To reach the maximum power level, RENNtech downpipe is required
M133 Stock Performance:
355 HP @ 6,000 RPM
332 LB-FT @ 2,500-5000 RPM
Modified Performance :
up to 460 HP @ 6,500 RPM
up to 415 LB-FT @ 4,000-5,500 RPM
RENNtech M133 ECU Upgrades are TÜV approved!
Our proprietary ECU upgrade for the Mercedes M133 engine offers huge gains in performance across the entire RPM range without sacrificing around town comfort or daily driver reliability.
Our ECU tune offers the biggest performance gains on the market with our dyno results increasing performance from 355 HP and 332 lb/ft torque, up to an astonishing 428 HP and 417 lb/ft at the crank!
CLA 45 AMG (C117 - M133 2.0L Engine) Stock Performance:
375 hp @ 6,000 RPM; 350 lb-ft @ 2,250-5,000 RPM
Note: Mercedes M133 engine performance when measured obtains higher numbers that rated from factory.
CLA 45 AMG (C117 - M133 2.0L Engine) Modified Performance:
428 hp @ 6,200 RPM; 417 lb-ft @ 4,300 RPM
PM me for A SPECIAL OFFER
Products:
Boost gauge: $480
Stage 1 Turbo: $5,980
ECU unit: $1,780
Application:
117 CLA 45 AMG
Ordering:
Payment Methods:
- Credit/Debit Cards (Visa, MasterCard, Discover, American Express)
- PayPal
- Bank Wire
- Bill Me Later
- AZ Orders will incur 7.8% sales tax
- All international orders (outside of US and Canada) require Bank Wire or PayPal
Shipping:
Most orders leave via FedEx, however we do use some private freight companies. The most efficient shipping method takes precedence. Expedited shipping is available by request.
Contact Information:
Phone: 480.699.8752
Email: justin@winnautosports.com
Website: www.winnautosports.com
Please feel free to contact me via PM, Email, or Phone if you have any questions.
Quick Reply: ▀▄ Winn Autosports ▀▄ | RENNtech performance upgrades
