Passenger airbag warning
i just got my car back from dealer and as soon as I picked it up, I had that warning.
faulty seat Buckle? That’s odd.
Yeah. The first time it appeared, it was while driving. Someone was sitting in the passenger seat but nothing unusual was going on. From then on, the warning would appear every time I started the car (I was hoping it might magically go away). I took it in and they said the front passenger buckle may be bad. They "exercised the pins" and the error went away. They still ordered the part since they thought it could be bad. They were apparently right since the error came back after a week or so (this time when no one was in the passenger seat). It took a little over a month for the part to arrive.
What made me mad is it was like that as soon as I picked the car up and they blantantly ignored it.
The car car has been in the shop almost as long as I’ve had it. If I go in for 2 other issues. I’m doing a lemon law. I don’t care how small the issues are, a $45000 small car should not have the build quality of a 10,000 one. The QC of this vehicle is substandard. Like the squeaky door panel. Just touch the same thing and it howled at you. Least they resolved it
...and it's back. The warning light came on again as I was driving into to work. No passenger, no bumps, just driving casually at slow speeds on side roads.
At this point, I'm debating if I should go to another Mercedes dealership to see if they'd have better luck diagnosing this. @Deriggs007, did you get your warning light fixed yet? Maybe I'll wait for that and see what solution they come up with for you.
2005 SLK 350 w AMG / 2008 C / 2019 A220
I have not gotten it back yet for the airbag problem. They had to order my sunshade that was damaged from the sunroof and probably haven't looked at it. I'll tell you what. If you don't have warranty, I would suggest purchasing it.
Sun SHADE replacement on the car was $1500. What a bunch of thief's.
Yeah, I got the extended warranty. I figured this is a first year model so it's worth it (also have the option to cancel up until a certain point so it seemed safe). Not sure how late you can get it but I'd suggest you consider getting it, too, if you haven't already.
Took the car in to have the airbag warning looked at again. They called and said they were awaiting guidance from Mercedes. Supposedly other new A classes have the same problem. They don't yet know if it's a software update, new controller, etc. They hope to have an answer Monday.
They called and said it's fixed. They replaced the SRS control module. I got a different error but seems same solution as mentioned here: https://mbworld.org/forums/class-w16...lfunction.html.
Hopefully it stays fixed this time.
