A-Class (W168, W169) A140, A160, A160 CDI, A170 CDI, A190, A210 Evo, A180
A160 (W169) Fuse Box
Old 07-07-2007, 08:44 AM
Lenvdb's Avatar
I drive an A160 CDI (W169). Great car given to me by my partner as a Birthday present.
Cool A160 (W169) Fuse Box
Hey all!
I discovered my Right hand side Headlamp suddenly no longer works. I assume the bulb has blown and got another H7 Bulb. I then figured out how to replace the bulb only to discover the bulb is still in good shape. Now I want to figure out where to find the Headlamp fuses. My Manual says its under the PASSENGER foootwell. I opened to find......nothing. It turns out it is under the front driver footwell. There is a Fuse Map chart there that indicates that the headlight fuses are on number 55/56. But my fuse box only contains up to #54.
As a result I am rather totally confused. Can anyone point me in the right direction here?
Many thanks
Len
Old 07-07-2007, 06:43 PM
bazzle's Avatar
http://www.svcglobal.com/board/html/...um.php?forum=1
Bazzle
Old 07-29-2007, 06:38 AM
JosvdL's Avatar
A140
Hello Len,
Next to the light switch there is a small panel located aoround the corner, of about 2x4 inches size, and behind that panel the specific fuses for the lights are located.
If you need more information please let me know.
Best regards,
Jos
Old 09-06-2008, 08:14 PM
tlat's Avatar
A160
Talking Fuse box
Hi
I have recently found where the main fuse box is....
but unfortunately i have lost the user manual and i don't no what fuse belongs to what....
Can anyone tell me which fuse belongs to the lights in the temperature controls...
Hope someone can help me
Tlat
Old 09-07-2008, 12:08 AM
Mike T.'s Avatar
2005 smart cabrio; 2008 Mercedes-Benz B 200
There should be a fuse list on paper, all neatly folded up, tucked into the fuse box. That should tell all.
Old 12-24-2008, 06:27 AM
DeveloperBob's Avatar
A160
Did you ever solve this problem - I have the same issue - drivers side light not working but the bulb is fine - I found the small fusebox on the side of the dashboard but these fuses all seem to be fine as well.
Old 01-13-2009, 11:41 AM
martin s hill's Avatar
a160 classic
hi len you say you have a fuse map ? i dont have 1 in my a160 i'm looking for the fuse that deals with the centre cluster time ? clock ? temp ? i dont know what fuse deals with this area can you help ?
kind regards martin hill
Old 08-12-2018, 05:27 AM
Egon1209's Avatar
2006 A200 W169
Hi, I couldn't locate the "side" fuses anywhere...
But did you manage to resolve this issue?
Old 08-14-2018, 04:10 PM
Chode McBlob's Avatar
No side fusebox on the W169 dashboard, only on W168's - people often confuse the two ...
Old 01-16-2020, 07:32 PM
Edwin Carter's Avatar
2007 Mercedes Benz r350
Edwin Carter
yes my left front headlight isn't working low beam or high beam in my back right tail light is it has no brake light is there for specific fuse for each
Quick Reply: A160 (W169) Fuse Box
