19" rims....whats the real deal?
Old Aug 13, 2002 | 01:11 PM
Pffelan's Avatar
CLK 430 Coupe + MGF + 1980 Camaro
can someone answer my questions in a once and for all manner?
sorry to be abrupt but i am tearing my hair out trying to mod my car.
00 430clk uk spec std 17" rims std suspension
the plan is eibach or h+r springs plus 19" rims
will it rub?
how wide a rim was thinking 8.5 f 9.5r ?
will i need to roll the archs? if i stick to 8" rims will i get away with stock archs?
do i ask too many stupid questions?
Old Aug 13, 2002 | 03:26 PM
thuged_out's Avatar
Re: 19" rims....whats the real deal?
will it rub?
With 19X8.5/9.5, H&R springs and stock pads the only time the back will rub is if you have passangers there. the fronts will not rub. you will need to roll the rear fenders, but very little. And Pffelan, always remember, there are no stupid questions, just stupid people
Old Aug 13, 2002 | 06:02 PM
IDOITBST's Avatar
Don not get eiback springs they suck
they cant even make each spring the correct length lol... also change your shocks cuz if you dont your just compressing the stock shocks all the aftermarket shocks are a bit shorter to compensate for the springs..!!!!!
Old Aug 14, 2002 | 04:20 AM
Pffelan's Avatar
cheers for the advice...
are the eibachs really that bad?
what tyres are the best compromise on the 19"?
i am assuming 235 f and 265 r?
Old Aug 14, 2002 | 09:53 AM
thuged_out's Avatar
yea, 235 and 265. here is the link to my car
http://www.wheelexperts.com/images/g...clkdemruyl.jpg
Old Aug 14, 2002 | 11:41 AM
Pffelan's Avatar
real nice car!
makes me wish mine was black.....
does tire wear increase dramtically with the 19" on ?
Old Aug 14, 2002 | 12:36 PM
thuged_out's Avatar
cant really comment on tire wear cause i only have driven about 5k miles. but tell you what, the tires i have on now (yoko avs sport) are much quieter than the POS continentals that the car came with. and as far as handling goes, the yokos are lighyears ahead of contis
Old Aug 14, 2002 | 04:40 PM
Pffelan's Avatar
do you have to drive in the wet...
have conti's at the mo and find them crap in the dry but strangely good in the wet... which it tends to be over here!
had bad experiace with yokos on fwd cars in the past...but heard the newer stuff is good.
Old Aug 14, 2002 | 05:10 PM
thuged_out's Avatar
yea, i drive in wet once or twice a year(live in so cal). i was driving back from san francisco to LA on PCH and it was raining like a moth***** but my yokos hndled beautifully. im only familiar with yoko avs sport. dont know about the rest
Old Aug 14, 2002 | 10:21 PM
IDOITBST's Avatar
i live in hawaii i have the p7000
tho a few notches down from like s03'z they work well... does tend to rain here lol i have 9500 miles on my car and still alot of tread..!!!!
Old Aug 19, 2002 | 09:51 PM
techbike's Avatar
All of them, as much as I can...
Yoko AVS stick like gum but plan to trash them after 12K miles. I would have gone for SO3s but only Yoko makes the sizes for 19s on CLK. 235 35 19 and 265 30 19s . Tyre pressure is also critical on the heavier CLK55. I found 43PSI front and 40PSI rear the best ride, traction, and wear combination. 2 or 3 PSI up or down from that really messes things up for my ride. Hope this helps..
Old Aug 21, 2002 | 10:30 AM
LowRydeR's Avatar
I have Brabus 19x8.5F 19x9.5R, the front rubs like crazy whenever I make turns. Suspension setup is H&R Sport, Koni Adjustable, and 1/1 Spring Pads, rolled all 4 fenders. STILL RUB even with spacers. Hope this helps.
-Bruce
