L.E.D. Conversion!
Old Aug 4, 2006 | 02:26 AM
CurYousGee's Avatar
2000 CLK 430
L.E.D. Conversion!
I started with the license plate....and then did everything else!
Attached Thumbnails L.E.D. Conversion!-img_0829.jpg   L.E.D. Conversion!-img_0833.jpg   L.E.D. Conversion!-img_0835.jpg   L.E.D. Conversion!-img_0836.jpg
Old Aug 4, 2006 | 02:29 AM
CurYousGee's Avatar
2000 CLK 430
I shaved down the LED in the city lights to make it fit thru the housing. I next changed out all the festoon bulbs to the LED in the interior of the car
Attached Thumbnails L.E.D. Conversion!-img_0837.jpg   L.E.D. Conversion!-img_0838.jpg   L.E.D. Conversion!-img_0839.jpg   L.E.D. Conversion!-img_0840.jpg
Old Aug 4, 2006 | 02:33 AM
CurYousGee's Avatar
2000 CLK 430
trying to figure out how to do the dash, but it seems to be a bit more complicated with finding the right LED, i want to change it out to white, but i guess the beam pattern isnt that great.
if anyone knows or has done this....hook me up!
Old Aug 4, 2006 | 05:47 AM
clkcrazy's Avatar
CLK 430
I did the same exact thing about a month ago...Nice
Old Aug 4, 2006 | 07:32 AM
blisscafe's Avatar
i bought a full set of blue and super white i use the blue for the car shows
i think that the led screen in the speed unit is not gonna change because of the backlights
Old Aug 4, 2006 | 10:32 AM
viguera's Avatar
CLK 320
Do you have bulb numbers and where you picked them up from?
As far as the dash, it could be those tiny LEDs that most manufacturers use, which are a complete pain in the *** to change over. A guy I know in RI does this for people, but it's like a couple of hundred LEDs to swap out... not sure if that's the same thing with our cars though.
Pics of his car months ago (he's got like 15 TVs in there now )
http://forums.maxima.org/showthread.php?t=430444
Old Aug 4, 2006 | 01:12 PM
CurYousGee's Avatar
2000 CLK 430
Do you remember how many LED bulbs you need for the Instrument clusters? will the T10 led wedge base work? just plug and play or do we need to hook up some resistor due to the voltage difference?
Old Aug 4, 2006 | 01:23 PM
CurYousGee's Avatar
2000 CLK 430
vig, heres the list of bulb from the ebayer us home direct
1. 3 - 8 LED 44mm Festoon white - for the front dome and rear
2. 1 - 3 LED T10 Wedge White - for the map light, need to shave down the sides a little to get it to fit in the little map light housing
3. 4 - 6 LED 39mm Festoon White - 2 for the door and 2 for the license plate, and you may need 2 more if you want to change the vanity lights on top of the sunvisor, and one more if you want to change the glove box.
4. 2 - 4 LED Ba9s bayonet White - for the city lights, need to shave down on of the metal prolongs so it will fit into the socket. if you want to go with the 5-LED then it may fit in some clks, not mine, i shaved down the LED a little to get it in there.
Remember they come in pairs and to get the super white.
For the license plate you need to hook up in parallel 100ohm 10w ceramic resistor from radioshack = no defective lamp warning
For the city lights need to do the same with the resistor, from autoillumination, midgetfinger said to use the 15-25w resistor they sell on their site, i tried it and so far it works ...but this one has metal heat sinks soo it does get a little hot...so keep it away from everything
George
Old Aug 4, 2006 | 02:49 PM
ThrillKill's Avatar
CLK/ML
Nice job!
Old Aug 4, 2006 | 05:00 PM
CurYousGee's Avatar
2000 CLK 430
thanks tk...i think i got a little obsessive and went over board on this mod....i even changed out the lights on my old accord
Originally Posted by ThrillKill
Nice job!
Old Aug 4, 2006 | 11:27 PM
blisscafe's Avatar
this is what your light bulbs look like inside your instrument panel http://replacement.autopartswarehous...0Bulb&dp=false they are clear bulbs the panel itself is colored amber so blue lights probably wont help
Old Aug 5, 2006 | 02:11 AM
CurYousGee's Avatar
2000 CLK 430
do those bulbs pop out of that plastic housing?
is the dash on the post2000 same as the pre2000? the dash looks white but your saying when back lite, it is actually amber colored? so trying to go with a pure white wont work?
Old Aug 5, 2006 | 01:46 PM
55 ON IT's Avatar
W208 CLK55K, GTR, RS5
Pretty cool! I would do something similar, it's just the I'm too f-in lazy.
Old Aug 5, 2006 | 02:17 PM
CurYousGee's Avatar
2000 CLK 430
I hear that!...been wanting to do this mod for 2 years now, i finally got around to doing it
