camber kit
Old Apr 30, 2007 | 08:11 PM
Lensolo's Avatar
99 C43 AMG
bump! got a few more sets left!
Old May 8, 2007 | 02:34 PM
deyainrdy4ds's Avatar
w208
i just dropped my car on H&Rs/bilsteins......but now i want to adjust the camber...if i got the camber kit while on my 18s right now and then change it up to 19s - will i have to completely redo the camber adjustment?
Old May 8, 2007 | 08:50 PM
Zoom On's Avatar
'02 CLK55
No you are adjusting the geometry of the suspension on the wheels.
How is the ride after the drop compared to stock?
Old May 8, 2007 | 10:23 PM
Lensolo's Avatar
99 C43 AMG
In theory, you really shouldn't have to adjust the camber just by changing the wheels but... Since you are probably going to be using a shorter aspec ratio tire(profile), you'll notice tire wear much faster than the 18s. The camber kit will definitely safe you some money in the long run with tires.
Old May 8, 2007 | 11:05 PM
Zoom On's Avatar
'02 CLK55
Originally Posted by Lensolo
In theory, you really shouldn't have to adjust the camber just by changing the wheels but... Since you are probably going to be using a shorter aspect ratio tire(profile), you'll notice tire wear much faster than the 18s. The camber kit will definitely safe you some money in the long run with tires.
I think what he was asking is will he have to redo the alignment after switching the wheels. Once the alignment is set 17,18 or 19 should not matter if aligned properly, correct?
Old May 8, 2007 | 11:31 PM
Lensolo's Avatar
99 C43 AMG
You are right. He won't have to get an alignment. What I was referring to was tire wear due to camber on 19" tires compared to 18".
Old May 8, 2007 | 11:50 PM
  #32
w208
aight kool thanks
the ride isnt too much worse, but i definetely feel the difference from the stiffer springs and shocks ...every bump on the road bangs louder and you feel the little bumps more but i dont mind it much...its not THAT drastic of a change and it definetely is worth it for me for the looks for one thing but it also handles a lottt better...heres a quick camerafone pic of it that i took today..i took better pics the other day but it was a lil higher since it didnt completely settle n my subs werent in the trunk...it probably has very minor settling to do at this point...
ill prob take sum better pics soon if i have a chance to before the bodywork...
Old May 9, 2007 | 01:49 PM
  #33
chrisbala's Avatar
aight kool thanks
that is looking sickkkk man, I so need an AMG kit - would have got one if it didnt cost an arm and a leg over here!!!
Old May 9, 2007 | 02:21 PM
  #34
w208
thanks man...ya the AMG kit is expensive ever here so prob even more there lol
Old May 9, 2007 | 02:37 PM
  #35
DropTop208's Avatar
02 CLK 430 Cab
Your car looks sick with that drop man. So what size pads did you go with?
Old May 9, 2007 | 04:27 PM
  #36
w208
thanks...i used #1e front and #4clk rear cuz my subs..it worked out pretty even but i PROB cuda pulled off a #3 in regards to evenness.....but i gues its strate jus in case i have passengers in the rear...
i just ordered a KMAC front and rear camber kit...anyone know how much install runs at most places and what kind of place i should go to? can i go to a regular mechanic or probably a custom auto typa shop?
Old May 15, 2007 | 02:40 PM
  #37
Lensolo's Avatar
99 C43 AMG
bump for TRACK TESTED camber kits!
Willow Springs Opentrack 5_9_07
Old May 24, 2007 | 08:44 PM
  #38
Lensolo's Avatar
99 C43 AMG
On ebay now.
http://cgi.ebay.com/ebaymotors/Merce...spagenameZWDVW
Old Jun 6, 2007 | 06:53 PM
  #39
Zoom On's Avatar
'02 CLK55
Ok have the Kmac for the front and looking to buy rear. Noticed 2 things the Kmac rear looks like bushings and adjustable bolts. Then I noticed from the pictures these look like adjustable arm and in Josh's case two. What is the difference and is one better?
Old Jun 7, 2007 | 10:32 AM
  #40
deltasonik's Avatar
2000 CLK 430
I noticed that too. On the website, Kmac shows the rear camber kit as a couple of bolts and there are a few that have the long bars what is the difference? They both claim to correct camber on the rear.
Old Jun 7, 2007 | 10:41 AM
  #41
Lensolo's Avatar
99 C43 AMG
KMac uses eccentric bolts to adjust camber and pretty much every other set out there are adjustable arms in the form of a turnbuckle. The difference is that camber can be adjusted to a much higher and lower degree with the arms than the bushing/bolt set. As far as which one is better? Well. Hmm.. Mine are. haha
And, the arms are much much easier to install.
Old Jun 15, 2007 | 02:43 PM
  #42
bbearden's Avatar
'03 E55 (My Daily), '01 ML 320 (Wifey), Twin Turbo '69 Camaro (In Progess)
Has anyone had a shop install the K-MAC kit in rear of their CLK? I took my ride to a local tire shop near myhouse and they claim to have needed to take the springs out to do the install. Apparently the bushing removal tool included in the kit broke almost instantly, making bushing removal a real PITA! What have others been charged for this install? I don't want to pay an arm and a leg, especially for an indy....
Old Aug 29, 2007 | 08:19 PM
  #43
babyjrluv's Avatar
2001 clk55 amg
where can you buy these House of Power's set of Trak Links camber kit for the rear? If anyone knows pls post it. Thank you
P.S Lensolo Do you still sell the rear camber kit?
Old Aug 29, 2007 | 08:29 PM
  #44
Lensolo's Avatar
99 C43 AMG
PM'd
