clk430 trans fluid help
Old Oct 5, 2008 | 06:32 AM
tastoto's Avatar
ck430 2002
hello people i would like to know what gearbox oil to use as im changing my trans oil any help is appreciated must it meet dextron 3 requirements i dont know.
Old Oct 7, 2008 | 06:28 PM
Hal H's Avatar
2001 CLK320
The 722.6 transmission uses full synthetic (MB specific) ATF.
Doesn't use Dexron or Mercon ATF - you can get the MB fluid through online retailers or buy it from your local MB dealer.
Old Oct 7, 2008 | 06:47 PM
gregory13lil's Avatar
2000 CLK430
ONLY USE MB FLUID
I changed mine about 1.5 years ago and I was told ONLY to use the original MB trans fluid.
I did it myself on a lift so I hope you have a lift if you plan on doing this yourself as well. It is going to be really difficult getting to some bolts without having the car up in the air.
Greg
Old Oct 8, 2008 | 12:57 AM
The Jury's Avatar
2002 c240
MB fluid only. It's $16 per qt and you need 7-8 qts.
Start saving...........
Old Oct 8, 2008 | 01:45 AM
sfclk's Avatar
1999 CLK320
what year? 98s and 99s have a torque coverter drain plug.
If I remeber right, we drained 9qts. Also, you don't need a lift, just raise the front as high as you can.
Make sure to replace the filter.
Old Oct 8, 2008 | 07:33 AM
2000 CLK430
You know what!!!!
You are right, I was thinking about the rear diff seal and fluid change. I dont know why I got the 2 confused LOL.
Sorry about the confusion.
Greg
Old Oct 8, 2008 | 06:14 PM
tastoto's Avatar
ck430 2002
thx
Old Oct 9, 2008 | 08:23 PM
sick430's Avatar
CLK Cabrio
i have been changing mine every 30K miles with regular transmission oil with no problem and i drive my car like i stole it 2/3 of the time. as long as you change every 30 no need to put synthetic.
just my 2 cents.
Old Oct 10, 2008 | 04:06 AM
tastoto's Avatar
ck430 2002
lool thats how we drive it though
Old Oct 13, 2008 | 06:23 AM
jreddyroc's Avatar
2002 clk 430
Greg
I own a 2002 CLK430 and I bought it when it had 127000km 8 months ago now it has now it has 157000km and all IV done is change the oil 3 times and I'm planning to get the tranny serviced as soon as I get the cash because I think its expensive at mb so I was thinking I will hold up for another month or 2 and service what IV missed in the last 30000
IV never own a mb and all my cars have been older like 1991 and IV had a few tranny problems so I'm really scared that the trannys gonna fail on this one but it is a newer car and every thing runs good and people say it a mb the quality is good don't worry
Should I be as paranoid as I am thinking my trannys gonna go any day because IV done so much driving in 8 months 30000km and all IV done is change the oil do these cars hold up well I hope I have couple of months to stack money for my car
Old Oct 13, 2008 | 08:33 AM
2000 CLK430
Jreddy,
You only have 157,000 KM which is about 95,000 miles so your tranny should still be in good condition and I wouldn't worry much about it. I would although do some maintenace on it. MB states that the tranny has lifetime fluid but when I changed mine at 100,000 miles (160,000 KM) it was already a nasty grey gummy color and I know that it was not lubricating much anymore. So I would suggest that you change both your Tranny fluid and your rear differential fluid. The tranny is really easy (just dont forget the bell housing) and the rear differential takes a little more time but it will be well worth it in the long run. Hope this helps!
Greg
