ESP AND ABS LIGHTS ON
After few minutes of driving these lights come on and the car drives in safe mode i have no idea
Originally Posted by tastoto
(Post 3129935)
just do a quick search. There is a very nice and detailed DIY on fixing this very common problem. |
Originally Posted by OPALW208
(Post 3130291)
(Post 3129935)
Are those the only lights on or is your check engine on as well? Last year, my instrument panel lit up like a christmas tree, and my car went into limp mode. A transmission flush fixed everything. I believe the last post telling you to do a search is suggesting that you have a stop lamp switch failure which is a common cause of the ESP and ABS lights coming on. IF the only symptoms are ESP and ABS lights, I would suggest replacing the stop lamp switch as well. Easy DIY and only $15 part from the stealership. |
