Eibach with 20 ich Wheels.. Need help...
Old Oct 25, 2009 | 10:31 PM
andrers83's Avatar
CLK 320
Hi,
May I put Eibach springs with 20" wheels ? or Will be able the tires to scrape in the can? I need change my springs, but I need know which is better O.E.M or Eibach. Remember, I have 20" wheels.
Thanks...
Old Oct 27, 2009 | 11:37 AM
andrers83's Avatar
CLK 320
PLEASE, anybody ???
Old Oct 27, 2009 | 12:21 PM
gregory13lil's Avatar
2000 CLK430
Williams will probably be the best person to answer this question since he runs 20's on his CLK.
Greg
Old Oct 27, 2009 | 02:20 PM
andrers83's Avatar
CLK 320
Gregory,
Yes, I know. But Williams use H&R kit. I need know about Eibach. I know the Eibach lowered 1.2", but it's possible run without problem with 20" wheels ?!... That's the question...
Old Oct 28, 2009 | 02:07 AM
CLK FAN's Avatar
2000 CLK 3.2
you will be fine with Eibach springs because they don't lower the car as much as H&R
the real question is what are your tire sizes and the offsets on the wheels and aslo what are the widths on the wheels?
Old Oct 28, 2009 | 08:28 AM
andrers83's Avatar
CLK 320
Hi CLK FAN,
Ok, let's go to information:
225/35 20 8"j ET 38 - Front with spacers 5mm
245/30 20 8"j ET 38 - Rear with spacers 6mm
What do you think CLK FAN ?
ps: thank you very much for you help....
Old Oct 28, 2009 | 01:21 PM
CLK FAN's Avatar
2000 CLK 3.2
Originally Posted by andrers83
Hi CLK FAN,
you'll be fine with those specs
you might rub on top with the fronts when you take a big dip or bump but nothing that's going to mess up your car
Old Oct 28, 2009 | 06:24 PM
andrers83's Avatar
CLK 320
CLK FAN,
Excellente, I will try.
See ya
Old Nov 4, 2009 | 09:27 AM
andrers83's Avatar
CLK 320
CLK FAN,
I have other question, What is it PAD#3 / PAD#2 ??? I put the Eibach and the front was very lowered and I want a little more high, because here in Brazil the road it's not like in California.
Thanks again for your attention...
Old Nov 4, 2009 | 10:47 AM
andrers83's Avatar
CLK 320
Other question, What size the original use PAD#1, 2, 3, 4 or 5 ? and, Which you recommend for me ?
Thank's
Old Nov 4, 2009 | 01:14 PM
vizionclk430's Avatar
2002 clk430
The only way you can tell your original pad is to actually feel them to see how many nubs is on it. All are different depending on what the factory put on yours.
Old Nov 4, 2009 | 04:43 PM
andrers83's Avatar
CLK 320
Vizionclk430,
I know that the rear are 4 nubs and the front are 5 nubs. I called to Dealer and they told me that has 5 sizes: 5mm, 9mm, 13mm, 17mm and 21mm. But, I don't have idea what size is 4 and 5 nubs.
Do you have any sugestion Vizionclk430 or anyone?
Old Nov 5, 2009 | 06:17 AM
andrers83's Avatar
CLK 320
Old Nov 5, 2009 | 06:46 AM
2002 clk430
This info is from marcus f on an old thread again the # one pad is the thinnest and this has the part # for when you go to the dealer
There is no universal 'stock pad'. Mercedes-Benz makes pads in these sizes: 5, 9, 13, 17, and 21 mm and they designate them in their part #'s by numbering them 1 (thinnest), 2, 3, 4, and 5 (thickest). The pads installed on a particular car are based on the equipment that came with that car. For example, a fully equipped 2002 CLK430 convertible probably has a different spring pad than a base 1998 CLK320 coupe. You can reach in and feel the number of bumps on the pad to determine which one your car currently has. The number of bumps will match the pad number.
Front:
210-321-01-84 5mm
210-321-02-84 9mm
210-321-03-84 13mm
210-321-04-84 17mm
210-321-05-84 21mm
Rear:
210-325-01-84 5mm
210-325-02-84 9mm
210-325-03-84 13mm
210-325-04-84 17mm
210-325-05-84 21mm
I hope that helps.
Old Nov 5, 2009 | 08:10 AM
andrers83's Avatar
CLK 320
Excellent vizionclk430..!!! Thanks for your help. When I solve the problem, I will put some pictures.
Regards
