CD changer upgrade
Old Jun 24, 2003 | 02:52 PM
O-Dawg's Avatar
CD changer upgrade
Does anyone know if it's possible to replace the factory-installed cd changer with a unit that will read CD-RWs? I can play CD-Rs fine, but the CD-RWs don't work (although they do work in the in-dash single-cd in my Z4).
Old Jun 24, 2003 | 02:55 PM
CiLKY's Avatar
13 S550 4Matic
Correct me if I'm wrong guys....but I think the CLK cd player is connected via fiber optic wiring(obviously not normal wiring) meaninf you can't swap it out unless you replace the whole deck/head unit. Try doing a search to see if anyone has posted about this before.
L8tr
Old Jun 24, 2003 | 02:57 PM
O-Dawg's Avatar
Yes, this is true, you would have to replace the entire changer. I was hoping the newer alpine units, perhaps those in the 2003 model, would be compatible, and that they would supprort CD-RW.
Mine is a 2000 with COMAND. I was hoping I could just purchase a new changer and install that instead.
Old Jun 24, 2003 | 05:40 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
I do not think it is possible to use an aftermarket CD Changer with an OEM Mercedes Headunit. I could be wrong, but any sound system equipped with the fiber optic deal will not work unless you swap the whole deal out.
Old Jun 25, 2003 | 04:02 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
There are at least two aftermarket CD changers I know of that work with the 1999+ Mercedes head units:
USA Spec
Becker
There also are a few that work with the non-fibre optic units, but the most popular is certainly the whatever's-current Alpine M-Bus changer.
I can't remember for sure, but I think the latest W203 changer may read CD-RWs. I'm fuzzy on this one though, but if it does, you can just hook it up in place of your old one.
-s-
Old Jun 30, 2003 | 12:09 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
Thanks for the heads up
I did not know that there were other CD changers that could work with 1999+ MBZ Bose systems. Thanks for the info!
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
