Does disconnecting the battery for 30mins clear fault codes?
Does anyone know if its true that if you disconnect the battery for 30mins + and the re-connect obviously following the reset procedure, that it will clear any fault codes on the car?
yeah I bought one of Ebay, havnt had time to try it , as I have have had to also buy a round pin adaptor to the rectangle obd 2. Also mines fitted in the engine not as you guys have inside the car in the US.
I got an engine diagnostic done yesterday for a MAF and there were old codes from the rear lights that must have been on there for years, so in answer to whether the codes get erased on disconnectin the battery, I think it deletes some but not all. The ECU had a non-volatile memory I think and so stay in the system.
