2002 CLK320 Soft top won't close
Old Apr 17, 2013 | 11:50 PM
MackayScanland's Avatar
2002 CLK320
I just purchased the car. I push the switch and the light blinks slowly.Was working fine when the person I bought it from tested it for me. Read some posts, although, I still can't get it to close. Headrest goes up and down. No leaks. The hatch did open, but I manually shut it after I had no luck. Any suggestion before I go to the dealer would be great! Thank you!
Mac
I also have a '79 300SD turbo diesel
Old Apr 18, 2013 | 11:58 AM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
Did you push up on the top to start the opening sequence?
Old Apr 18, 2013 | 03:02 PM
2002 CLK320
Thanks for the reply. Took it to a shop and they reset something. Fix: Long screwdriver in trunk (release pressure?), manually open hatch with special tool, we manually put the top up, now seems to work just fine)) Was not roll bar sensor, said something about the sensor in track, and needed to reset itself. Thanks for being here for the info!!
Mac
