Door Contact Switch
Old Feb 28, 2018 | 05:34 AM
Opalatal's Avatar
CLK 320
Door Contact Switch
I've picked up a 2000 CLK-320 Convertible.
Mechanically the car seems great no major issues that need attending to.
Two areas of concern, however.
One of the Door Contact Switches have stopped working, so the interior light stays on and the window on the car will not fully close as it stays dipped thinking the door is open. Cheap enough fix, however, I can't seem to figure out how to get access to the back of the switch to remove it. All of the videos I've found have been for 4 door cars.
Secondly, the driver's electric seat is playing up. Forward and back functions only go forward on both the base and the back rest. You need to use the memory functions to move the seat back. So the motor has no issues going backwards just that the switches both send it forward. Could this either be the switch or the computer? A minor inconvenience but annoying just the same.
Old Feb 28, 2018 | 10:37 AM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
Generally with the contact switches, you remove the inner weather stripping in the area you need to access, and then pop a few clips off the B-pillar area to remove and install the new switch.. Do you have a picture of your difficult area to access?
With the seat operation, generally that means the seat has lost its normalization and needs to be reset. Most times you can do this by just moving the seat to all of its maximum movements, up/down, forward/back, etc..
Old Mar 3, 2018 | 06:36 PM
Opalatal's Avatar
CLK 320
Thanks for the reply Racin_Fool. I have managed to fix the issue with the windows, I discovered the contact switches were working fine and I just needed to pull the battery and reset all the windows. The only issue is I appear to have the wrong code for the radio, the lovely lady who previously owned the car must have had warranty work done and had the unit replaced as the code supplied with the car does not work. A simple call to Mercedes should hopefully fix this issue.
I googled around and attempted to 'Normalize" the seat but I can't seem to get it to work. The seat only wants to move the base forward even if I push the backwards direction on the controls. As mentioned the memory recall function moves it back to the original position. Is there possibly a wiring issue with the controller?
Old Mar 3, 2018 | 08:43 PM
Desert Panther's Avatar
1978 300CD, 1985 300SD, 2002 CLK430 Cabrio
Question
My recently acquired CLK is doing this very same thing with the drivers door window. Can you explain this "reset" for the windows? Or point me in the right direction?
Old Mar 4, 2018 | 07:04 AM
cindyclk's Avatar
all the reset procedures for all MB cars same (windows, seats, sunroof)...move the seat all way forward and hold the switch 5-10 seconds...that sets the "limit" of travel...alll positions same...windows same except be sure that you don't "auto" up and down to get the window into the correct position.
Old Mar 4, 2018 | 07:09 AM
cindyclk's Avatar
Did you move the seat all the way forward and then hold the switch there...usually after you set the forward limit, it cancels the rear limit....sounds like your rear limit is seat way forward.
Old Mar 4, 2018 | 07:47 PM
Talking Thank you CindyCLK
Thanks so much! My drivers window is now working again like it should! Now if I could only get the rear wing window on drivers side to raise up. It seems permanently stuck down, although I can hear a motor running when the switch is depressed. Any idea what that could be? Is there a known weak point in these windows? Or specific areas of concern?
Old Mar 6, 2018 | 05:38 AM
Opalatal's Avatar
CLK 320
Thank you so much for the help.
I moved the seat all the way forward and held it there for 15 seconds and I has not changed anything. I have a feeling it may be the actual switch that is playing up, as mentioned before I push forward and the seat goes forward, I push backward and the seat moves forward
