Lowering the CLK
I was looking at eibach springs or H&R but i've heard you can't just lower the car with springs that you need to change the shocks ect. also?
I've seen on here mixed reviews with Eibach vs H&R, which have a more comfortable feel? im not huge on performance i just want the new wheels to look nice and tuck with a stock feel.
I have 19's and lowered the ride with Eibach set up...then changed out the shocks at a later time....the ride is nice and handles great!!
good luck.
19's will look good on the car...then if you want a slight 'drop' you can get the Eibach Pro-Kit (it lowers the car 1.2" all around)...while keeping your stock shocks, your ride comfort will still be good and the handling upgraded...that's what I started out with...then 1yr later I added the Eibach Pro Dampers....even better handling. My car looks slightly dropped but not over aggressive....just kept it clean.
When You lower the car
As The stock shocks are worn at a Certain height on the shock piston..and WHEN You lower the car with different springs the height is changed on the shock and most times the seals will start to show signs of wear/leaking
Also the Stock shock has a longer travel than a Lowered Shock..and if a stock shock is used on a lowered car..When You Bottom out the car hard one can damage the shock as the travel is not long enough to go with the shorter springs...Been There!
anyone??
approximate total cost + install???
Here are some pix of my car.. just went with a little drop (used 1.2" all the way around--Eibach springs & damper kit) If I remember, the total cost was about $800 (parts & labor)...I had them done almost 2yrs ago...no problems...no rubbing and the ride is smooth with better handling on corners...Of course I take it easy on the roads
IMO H&R and Eibach are great brands (had them on other cars as well)...I prefer Eibach for the benz since I didn't want to go with an aggressive drop..
what size wheels you running? and you said you installed pro dampeners after the original lowering kit. is $800 the total cost of your current set-up?
Yes, $800 was the total cost of the set up...I feel that it was a great investment....I previously had a 325i fully modded with a more aggressive lowering---it was good for the time, but when I got a benz, I knew that I wanted to keep the 'famous benz' ride comfort, so just dropping it a little was best for me...
